Any supported way to install i3?
I have checked the Resources category Resources Index
6.0 (Vanadium, ROCK)
Currently, Plasma 6. Attempting to move to i3 window manager.
I am trying to verify if i3 is in OpenMandriva’s repositories, whether one I am not aware of, or did not install by default. I’ve noticed programs tangentially related to i3 (such as i3lock) is down when a dnf search i3 is entered into the terminal.
Relevant information (hardware involved, software version, logs or output…):
N/A to my knowledge at this time given the previous content of the post.
Thanks for reading!
i3-wm
You have to enable extra repository
Software Repository Selector | OpenMandriva wiki
Hey @rugyada , thinking ahead of time: I was looking for way to manage OpenMandriva Lx repositories outside of om-repo-picker, i.e. via the command line. I think I may make a pull request for Software Repository Selector | OpenMandriva wiki on this.
Do you know how one would ideally do so for OpenMandriva Lx? I’m used to apt, so I looked for something like /etc/rpm/sources.list, but that doesn’t appear to exist. I’m looking through how other distros manage rpm repositories as we speak.
You find the .repo files in /etc/yum.repos.d. If you know which one you are using you can easily edit these files.
For Rock:
/etc/yum.repos.d/openmandriva-rock-x86_64.repo
or:
/etc/yum.repos.d/openmandriva-rock-znver1.repo
For ROME:
/etc/yum.repos.d/openmandriva-rolling-x86_64.repo
or:
/etc/yum.repos.d/openmandriva-rolling-znver1.repo
Normally we use 8 in Rock:
main/release (should always be enabled)
main/updates (should always be enabled)
extra/releiase (optional) (not enabled after defalt install)
extra/updates (optional) (not enabled after defalt install)
non-free/release (optional) (not enabled after defalt install)
non-free/updates (optional) (not enabled after defalt install)
restiricted/release (optional) (not enabled after defalt install)
restricted/updates (optional) (not enabled after defalt install)
ROME normally uses 4:
extra/release (optional) (not enabled after defalt install)
Hey @ben79,
Thank you sincerely!
I appreciate how comprehensive your overview of OM’s yum.repos.d is. I will absolutely make good use of it. :grin:
Thanks for @rugyada for pointing me towards the initial article. It severely assisted with me being able to craft a “good” question. I don’t know if I can mark two solutions, I’ll try to mark the most fitting one for this thread.
