I tried to install amule but dnfdrake reported the package is not found in repositories.
Any hint?
[MIRROR] amule-2.4.0-8.git.20231116-omv2390.x86_64.rpm: Status code: 404 for http://mirror.openmandriva.org/rock/repository/x86_64/extra/release/amule-2.4.0-8.git.20231116-omv2390.x86_64.rpm (IP: 140.211.11.99)
[MIRROR] amule-2.4.0-8.git.20231116-omv2390.x86_64.rpm: Status code: 404 for http://abf-downloads.openmandriva.org/rock/repository/x86_64/extra/release/amule-2.4.0-8.git.20231116-omv2390.x86_64.rpm (IP: 140.211.169.10)
[FAILED] amule-2.4.0-8.git.20231116-omv2390.x86_64.rpm: No more mirrors to try - All mirrors were already tried without success
Yes I am old and sometimes cranky but this stuff really baffles me. It is not as if anything we are asking for is really that difficult.
Edit: @Marco could you please edit your first post to post that code as code instead of using quote?
Edit-2: With the information provided I could only answer your question partially (because I do not know the command you used) not completely so as for you to avoid this in the future. Also I’ll admit I sometimes forget to include all the info needed myself so please take my criticism as constructive.
I wrote that the error message came from Dnfdrake, so honestly I thought it was sufficient. I did not use any command; I just searched that package in dnfdrake and pushed the install button.
Sorry for not specifying that I am using the latest Rock and for using quotes instead of code (I thought that error message were not considered as code). Good to know it!
And I missed your comment about dnfdrake. Apologies. I having difficulty realizing people actually trust GUI package managers, I certainly do not. If I had an error in dnfdrake the first thing I would do is open Konsole and try commands there. Here’s why:
Notice that this is Rock/6.0 x86_64 system (note the commands used):
Yes, there is something wrong with the naming. It worked as of Jan. 17, 2025 but not now. This is an unmaintained package and I really do not want to get involved.
I have updated the package spec file to fix the version-release issues which were resulting in DNF not viewing it as an updated package release, I have also applied patches to get it building on latest boost 1.89 and rebuilt it on our ABF for cooker.
Regarding the packages’ longevity:
Upstream amule has not made a release since 2021, in their git repository there are a whole bunch of unanswered pull requests sitting awaiting review & merging.
Many distros do no package amule any more which is probably due to the so called maintenance burden on having to cherry pick patches from pull requests to make it build.
With that said the longer it goes without updating and making official releases the harder it will become to maintain because all the libraries it relies on have moved on since its last release and many of those library’s older api’s are in the process of being deprecated - the build logs are full of deprecation warnings as evidence of that.
In the meantime we have it packaged in our repos, but the clock is ticking on it I think.
I was thinking of making a post requesting that amule users look for alternatives. This package is getting to be to much trouble to deal with. It is to time and resource consuming to try to keep building something that is abandoned/not maintained upstream.
Edit: I did backport the new rebuilt package to ROME(rolling) and Rock/6.0. Do an internet search for:
I just wanted to let you know that differently from the past versions that sometimes hanged for lack of memory reasons, on my system (OMA LX 6.0 rock with kernel 6.14.2-desktop-3omv2590) the latest version of Amule you made available is running really fine.
