The first time I start kmail under a new user it terminates with a fatal error and an error report akonadi-selftest-report-20180620.txt (20.0 KB). Akonadi seems to be in trouble.
This is not a problem. I suspect that the kmail environment was not set up quite for the new user. I have had this error myself but kmail works just fine.
Colin
File content of ‘/home/vhelmont/.local/share/akonadi/akonadi_control.error.old’:
Unable to register service as “org.freedesktop.Akonadi.Control.lock” Maybe it’s already running?QFileSystemWatcher::removePaths: list is emptyQFileSystemWatcher::removePaths: list is empty
Try removing or moving that file if you want to get rid of the error.
Post edit: FWIW: @Colin is far more knowledgeable about KMail than I am. I don’t use it.
Post edit-2: Plus to ease your mind all that is telling you is that a “Previous Akonadi server error log was found”. It is the “/home/vhelmont/.local/share/akonadi/akonadi_control.error.old”
so remove it I’m thinking.
