I realize as issues go this ain’t likely the most important for developers…
When I boot ISO live the image ‘/usr/share/sddm/themes/breeze/components/artwork/background.png’ displays on the sddm login screen. That is the one with the yellow flower designed by Cristina. After I install system (hardware) it is no longer displayed only a boring plain blue screen. Any idea why this is? How to fix?
I’ll be checking this on VBox later today but as I remember it is same.
So if you go to sddm login screen right now you have the background with the yellow flower not a plain blue screen? I have and have had since installing a plain blue screen.
I’m sure that I can help you to get back the flowered bg. It will be done asap. Problem solved.
What it’s interesting to know is why it happened, and more if it’s your local issue or it is affecting also other users.
I found out what causes this. If you do a fresh install (ISO build ID 1180) you have the flower background on sddm login screen. However if you change anything in SystemSettings>Startup and Shutdown>Login Screen (SDDM) you then get changed to the plain blue background. As far as how to get it back after changing anything there I don’t know what to do.
