Hi, I get a Publishing error status message for two packages actually published. So, pragmatically, isn’t too important, but I would like to understand better the ABF workflow.
I read this thread and tried that solution, but without success… or maybe I just didn’t understand it ![]()
Thank you.
For some reasons (wrong permissions?) the first time all files into media_info directories should be deleted.
So from Platforms > caig_personal > Contents you may try to delete all files form all media_info directories into your repository. Then you may recreate them from Platforms > caig_personal > About platform > repositories/main > About repository/Main/Edit > Extra actions you may try to delete all files form all media_info directories into your repository or try to rebuild your packages.
It works \0/ thanks a lot!
It is strange you have multiple publish.log files. You may try to ask at IRC for this.
I believe because I triggered multiple time the Publish button in my tries before to ask
I’ve hit “Publish button” and these packages got published
