@AngryPenguin Hi. Installed Cooker Xfce Build # 1356 from ABF into a VirtualBox. It installed and updated successfully.
om-repo-picker (as was the case with Build 1308) would not save the Cooker Non-Free repo, nor prompt for root password, was able to add via dnf config-manager.
For Build 1356: Firefox crashes. It only displays the title bar and window border for a few seconds, then closes. Running it from a terminal produced this output:
~]$ firefox
console.error: Region.jsm: "Error fetching region" (new TypeError("NetworkError when attempting to fetch resource.", ""))
console.error: Region.jsm: "Failed to fetch region" (new Error("NO_RESULT", "resource://gre/modules/Region.jsm", 421))
Exiting due to channel error.
