https://abf.openmandriva.org/platforms/rolling/products/23/product_build_lists/1265
When the image from this build (has Plasma in the name) was installed, the default repos were set to Cooker, not Plasma.
I’ll double-check what I downloaded. Thanks.
It was 1265 that I downloaded/installed. When firstI launched the repository picker after the install, the pull down menu displayed Cooker. I installed it in a VirtualBox, so the install was easy to delete and start over. When installed the second time, it was on Rolling. Things happen.
Thank you for checking it though.
