Recently, sometimes the icons for notifications and status (network manager, battery, notes, etc see attached image ) ) just stop being useful: one just can no longer control network manager or just what to do with a pendrive. Everything looks fine if I logout and logon again.
What is this? Has somebody else experimented this? How to fix this without logging off?
When it happens are you able to see anything relevant in journalctl, or /var/log/Xorg.0.log, or /home/<user_name>/.local/share/sddm/xorg-session.log? Most likely something in journalctl or xorg-session.log?
I have seen things on the menu panel freeze a few times but probably never when it was inconvenient to logout/in.
Maybe OT (or not): The other freeze/crash I still see with KDE/Plasma5 desktop is that in a fresh install SystemSettings5 has to crash once or twice for your desktop to be “Official”. After the initial crash or two I never see it crash again. After you get past that then the only thing I see anymore is this (for me rare) menu panel freeze.
The panel icons don’t freeze actually. If one click on them, a blue bar appears over them as usual but no functionality is provided. Next time, I’ll look at journalctl and other files …
Hi,
I often experience the same behaviour. I simply add a new system tray which works well … for a while.
I dont’t know if this is related but when I don’t use the computer (which is still running) for several hours, plasmashell disappears though the opened windows are still working. I can switch the desktops using the usual keyboard shortcuts.
