Hi,
did you try to set up the sound output with pavucontrol (thumbnail “configure”)?
pujithadimuthu
(Pujitha Dimuthu Weerakoon)
December 9, 2017, 12:36pm
3
No. Now I tried. I changed to 5.1 does not give a output.
Do I need to re login?
What is the option I select from Drop down?
You might have to switch off one card to let the other work.
pujithadimuthu
December 12, 2017, 6:08pm
5
Profile Information displays only HDMI 5.1, HDMI 7.1 etc. But no 5.1 channel.
Hum, your card may not be well recognized.
Can you see its name and the associated driver when you launch in a console as a simple user:
pacmd list-cards
pujithadimuthu
December 14, 2017, 1:00am
7
[dimuthu@pujitha-pc ~]$ pacmd list-cards
2 card(s) available.
index: 0
driver: <module-alsa-card.c>
owner module: 6
properties:
alsa.card = “1”
alsa.card_name = “HDA NVidia”
alsa.long_card_name = “HDA NVidia at 0xfcffc000 irq 17”
alsa.driver_name = “snd_hda_intel”
device.bus_path = “pci-0000:01:00.1”
sysfs.path = “/devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1”
device.bus = “pci”
device.vendor.id = “10de”
device.vendor.name = “NVIDIA Corporation”
device.product.id = “0be3”
device.product.name = “High Definition Audio Controller”
device.string = “1”
device.description = “High Definition Audio Controller”
module-udev-detect.discovered = “1”
device.icon_name = “audio-card-pci”
profiles:
output:hdmi-stereo: Digital Stereo (HDMI) Output (priority 5400, available: no)
output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (priority 300, available: no)
output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (priority 300, available: no)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (priority 5200, available: no)
output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (priority 100, available: no)
output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (priority 100, available: no)
output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (priority 5200, available: no)
output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (priority 100, available: no)
output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (priority 100, available: no)
output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (priority 5200, available: no)
output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) Output (priority 100, available: no)
output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) Output (priority 100, available: no)
off: Off (priority 0, available: unknown)
active profile:
ports:
hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: no)
properties:
device.icon_name = “video-display”
hdmi-output-1: HDMI / DisplayPort 2 (priority 5800, latency offset 0 usec, available: no)
properties:
hdmi-output-2: HDMI / DisplayPort 3 (priority 5700, latency offset 0 usec, available: no)
properties:
hdmi-output-3: HDMI / DisplayPort 4 (priority 5600, latency offset 0 usec, available: no)
properties:
index: 1
owner module: 7
properties:
alsa.card = “0”
alsa.card_name = “HDA Intel”
alsa.long_card_name = “HDA Intel at 0xfdff8000 irq 25”
device.bus_path = “pci-0000:00:1b.0”
sysfs.path = “/devices/pci0000:00/0000:00:1b.0/sound/card0”
device.bus = “pci”
device.vendor.id = “8086”
device.vendor.name = “Intel Corporation”
device.product.id = “27d8”
device.product.name = “NM10/ICH7 Family High Definition Audio Controller”
device.form_factor = “internal”
device.string = “0”
device.description = “Built-in Audio”
profiles:
input:analog-stereo: Analog Stereo Input (priority 60, available: unknown)
output:analog-stereo: Analog Stereo Output (priority 6000, available: unknown)
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (priority 6060, available: unknown)
output:iec958-stereo: Digital Stereo (IEC958) Output (priority 5500, available: unknown)
output:iec958-stereo+input:analog-stereo: Digital Stereo (IEC958) Output + Analog Stereo Input (priority 5560, available: unknown)
active profile: output:analog-stereo+input:analog-stereo
sinks:
alsa_output.pci-0000_00_1b.0.analog-stereo/#0: Built-in Audio Analog Stereo
sources:
alsa_output.pci-0000_00_1b.0.analog-stereo.monitor/#0: Monitor of Built-in Audio Analog Stereo
alsa_input.pci-0000_00_1b.0.analog-stereo/#1: Built-in Audio Analog Stereo
ports:
analog-input-front-mic: Front Microphone (priority 8500, latency offset 0 usec, available: no)
properties:
device.icon_name = “audio-input-microphone”
analog-input-rear-mic: Rear Microphone (priority 8200, latency offset 0 usec, available: yes)
properties:
analog-input-linein: Line In (priority 8100, latency offset 0 usec, available: yes)
properties:
analog-output-lineout: Line Out (priority 9900, latency offset 0 usec, available: yes)
properties:
analog-output-headphones: Headphones (priority 9000, latency offset 0 usec, available: no)
properties:
device.icon_name = "audio-headphones"
iec958-stereo-output: Digital Output (S/PDIF) (priority 0, latency offset 0 usec, available: unknown)
properties:
ben79
(Ben Bullard)
December 14, 2017, 2:19am
8
pujithadimuthu:
available: no
I see a lot of available:no on my system too. My guess is that we have available:no because we don’t have any sound hardware connected via hdmi? But that is only a guess. Is hdmi connection the only way to have Digital sound from a computer? Do you have a 5.1 sound system connected to your computer? If so how is it connected?
I honestly don’t know much about how sound works on Linux computers but it looks like you can only select from options that are actually connected (plugged in).
pujithadimuthu
December 14, 2017, 3:26am
9
device.vendor.name = “NVIDIA Corporation” and device.vendor.name = “Intel Corporation”
But both are wrong.
NVIDIA Corporation for VGA
Intel Corporation for Motherboard 5.1 Output. (2 Channel Works) - Default Driver
Motherboard Foxconn G31MX has 5.1 channel, Realtek® ALC662
As I remember Mandriva 2009 or 2010 or 2011 had a Driver that support 5.1 channel. Not clear memory for me.
pujithadimuthu
December 16, 2017, 3:36am
10
For KDE Crash. Hope this will help.
KDE Carsh Process ID.txt (6.6 KB)
pujithadimuthu
December 18, 2017, 8:17am
11
I removed all the desktops I installed. Mate, LXQT, Cinnamon and Openbox. None of them Worked Properly.
Mate does not show in the login Screen Option. I kept Plasma.
Now PC does not stuck and works better. I can install software and update system easily. Most People work on KDE or Gnome. I think OpenMandriva should focus on another good Desktop Environment (2) works well with the OS too. KDE Crash is still happening.
