Using teamviewer
Has anyone used with success teamviewer_12.0.85001_i38?. I could install it but no GUI running. When it runs on terminal the output is:
Init…
CheckCPU: SSE2 support: yes
XRandRWait: No value set. Using default.
XRandRWait: Started by user.
Checking setup…
Launching TeamViewer …
Launching TeamViewer GUI …
And stays there for ever. Any luck anyone?
A good guess would be a missing or incorrect dependency. You could request the package be built for OpenMandriva here. Title it as a package request and under importance select trivial/enhancement.
