Hi,
I tried to Upgrade OpenMandriva Lx 2014.2 to OpenMandriva Lx 3 by following the instructions given
https://wiki.openmandriva.org/en/3.0/Release_Notes#Upgrading_from_previous_OpenMandriva_Lx_Releases
commands I executed
urpmi.removemedia -a
urpmi.addmedia --distrib --mirrorlist ‘http://downloads.openmandriva.org/mirrors/openmandriva.3.0.i586.list’
urpmi --auto --auto-select --replacefiles 2>&1 | tee /root/upgrade.log
some errors were generated saying some packages can not remove. but commands were executed.
I reboot the system. Did not updated to OpenMandriva Lx 3 but booted OpenMandriva Lx 2014.2.
now i can not install any software or MCC does not work.
I get this error.
[root@Pujitha-PC pujitha]# urpmi --auto-select
Perl API version v5.16.0 of URPM does not match v5.20.0 at /usr/lib/perl5/5.20.3/i386-linux-thread-multi/DynaLoader.pm line 216.
Compilation failed in require at /usr/lib/perl5/vendor_perl/5.16.3/urpm/msg.pm line 8.
BEGIN failed–compilation aborted at /usr/lib/perl5/vendor_perl/5.16.3/urpm/msg.pm line 8.
Compilation failed in require at /usr/lib/perl5/vendor_perl/5.16.3/urpm.pm line 8.
BEGIN failed–compilation aborted at /usr/lib/perl5/vendor_perl/5.16.3/urpm.pm line 8.
Compilation failed in require at /usr/sbin/urpmi line 26.
BEGIN failed–compilation aborted at /usr/sbin/urpmi line 26.
Please HELP me.
Thanks.
Pujitha
