Distribution Upgrade OM Lx 4.2 to Rolling
Currently (2022-01-01) you would be upgrading from OM Lx 4.2.
Important: A fresh install is always preferred over a distribution upgrade. I set up my work systems with independent data partitions so I can easily do a fresh install if there are problems.
  1. Preparation:
    a. User needs to be sure they have enough free space on their / (root) partition to do this transition. It is difficult to know a precise number for this as people add software and everyones system is different. We do know that applications like Flatpak eat up a lot of disk space. For now it is estimated that for most users 5 GB of free space should be enough.
    b. Before proceeding you should fully upgrade your OM Lx 4.2 system.
  2. Disable any and all third party repositories like google-chrome, ect. You can enable these again after the distribution upgrade.
  3. The actual transition process begins: Change your repositories (all of them) from either Rock or Release to Rolling with the “Software Repository Selector”. Note: It is very important that all of your repositories are for the same branch, in this case Rolling so every single repository should have Rolling in file name. Disable for now all non-free, restricted and unsupported repositories. This way you are mostly upgrading “system” software. The other stuff can be upgraded after this transition.
    Check that you have only Rolling and Rolling updates repositories enabled with this command:
    $ dnf repolist
  4. About the Rolling upgrade.
    This is a major upgrade. Like any major software change you absolutely have to do this the correct way.
    It is ultra, hugely, majorly, important that you run “dnf clean all ; sudo dnf clean all” before doing this procedure. dnf clean all removes anything leftover in cache and forces dnf to download the latest metadata from repositories ensuring that users gets the latest available software. Do not skip this step.
    Do not use sudo dnf upgrade for this.
    It is important that you upgrade to Rolling the correct way:
    $ dnf clean all ; sudo dnf clean all ; sudo dnf distro-sync
    At the end there are some questions asked about keeping current file or installing the package maintainers version. Normally accepting the defaults is safe. Packages you for sure want to keep the existing file are the ones that have your users, groups, and passwords. They are:
    /etc/gshadow
    /etc/passwd
    /etc/shadow
    /etc/group
    For those always select to keep the existing file.
    Note: Do not use Discover or dnfdragora to upgrade a Rolling system. They use a command that is fine for our regular stable release but is not correct for the dynamic changes that happen with Rolling.
  5. Next do this to install pipewire-pulse for sound and to switch from obsolete kysysguard to plasma-systemmonitor:
    $ sudo dnf remove ksysguard ; sudo dnf install pipewire-pulse plasma-systemmonitor
  6. Optional but recommended. Remove packages installed as dependency but which are no longer needed by any package. (In other words remove useless packages.)
    $ sudo dnf autoremove
  7. Reboot into your new Rolling system.
  8. If you encounter any problems please report each issue in a new post in the Support Forum with a descriptive title and enough information so other people can help.
Note: Sometimes it may be necessary to add the option --allowerasing to the main command to get everything to work. Like this:
$ dnf clean all ; sudo dnf clean all ; sudo dnf --allowerasing distro-sync
If you do this pay attention and be smart and write down any packages erased/removed so you can re-install them later if needed.
Note: There is an excellent “How To” describing this process with screen-shots here. The screen-shots can be especially helpful for users struggling with decisions in the dialog at the end where the system asks if you want to accept new files created by package maintainer or keep your old files.
Whether you answer yes or no to keep files or accept the new version depends on the file. For /etc/passwd , /etc/shadow , /etc/group , and /etc/gshadow you generally would want to keep the original files. For .repo files or files about grub2 you generally want to accept the new files. There sometimes may be other files with these Y or N questions.
I will ask developers a few questions about this and post some more about this here later.
I just found out here that some users may be affected by this bug.
Edit 2022-01-01: The bug mentioned in this post has been fixed.
I just found out here that some users will be affected by this bug after they reboot.
First you have to remove the old symlinks to these:
$ sudo rm /usr/lib64/libicudata.so.68 /usr/lib64/libicui18n.so.68 /usr/lib64/libicuuc.so.68
Then you need to create new symbolic links between these:
$ sudo ln -s /usr/lib64/libicudata.so.69.1 /usr/lib64/libicudata.so.68
$ sudo ln -s /usr/lib64/libicui18n.so.69.1 /usr/lib64/libicui18n.so.68
$ sudo ln -s /usr/lib64/libicuuc.so.69.1 /usr/lib64/libicuuc.so.68
Edit: You are removing an outdated, incorrect link to the .so.68 files and replacing the link with the correct, updated one. I have done this multiple times in VBox VM’s and in hardware systems.
As of 2021-06-04 Rolling is also OM Lx 4.3. When we do the final (GA) release of OM Lx 4.3 we will split the repositories and OM Lx 4.3 will become our latest stable branch. Rolling will still be Rolling and will eventually become OM Lx 5.0. At least that is the current plan. One starts to see how Rolling just keeps rolling.
This thread updated 2021-06-25 to reflect knowledge gained from our users and contributors.
This thread updated 2022-01-01 to reflect knowledge gained from our users and contributors.
How I test this:
  1. Create x86_64 and/or znver1 OM Lx 4.2 VM in VirtualBox.
  2. Update the Lx 4.2 system.
  3. Follow step by step the procedures in first post.
So this represents doing this on a default installation. Users that make a lot of changes may run in to problems with the distribution upgrade. If you do be prepared to do a fresh install if you can’t fix your issue.
If a user has problems with sound using pipewire-pulse you can instead use pulseaudio-server. To make this change:
$ sudo dnf remove pipewire-pulse ; sudo dnf install pulseaudio-server
pipewire-pulse is currently scheduled to be the default for OM Lx 4.3.
