I am putting this on Coffee Break because I have no idea what I am doing I have never done this before and I cannot guarantee this will work. However, I would like help in testing if you are willing and have time.
I made this file using qbittorrent. Please tell me if it works. This is for the Wayland version of OpenMandriva ROME. Thanks.
Edit: There are other ways to do this but I am trying to do this myself. However, I do not have a port open on my router, and that would require me to schedule a visit from the technician guy here. Or at least speak to my ISP. Please check back another time. Or feel free to come up with your own solution.
Edit: after adding these trackers manually on two devices on separate networks I am seeing both of them connected as leeches. Still no seeds available.
I have done so, updated files, tried again on my virtual machine, but it simply won’t connect. Am I missing something?
Also thank you for your contribution and time.
EDIT BELOW
I am pleased to inform this is now working! All I had to do was changing the incoming port to 1337 to equal that of the torrent, and I was successfully able to download this on my virtual machine. Please test on your end if you can for further confirmation. Thank you.
That is unfortunate. I am not sure how to fix this. It probably works for me since it’s the same network but not for anyone else, which isn’t what I want.
Do you mind recloning the github and trying again? Maybe it’s the file?
Btw, I realized you made a fork and I tried your file but nothing downloaded here for me. It stays stalled.
I deleted a file accidentally, so I had to make a torrent for the x11 version. I am now redownloading the wayland files………………
Do check the new .torrent file for x11 rolling omv. If you are on qbittorrent, set your incoming port for connections to 0 (any).
