@TPG I’ve just built some null project on official repo instead of mine . I apologise for the inconvenient and please ignore them. in this way I discovered abf get clone from openmandirva repository instead from mine. Is there a way to (fork and) clone from my own repo?
Is fork the command to start to work on a package in my repo?
$ abf fork openmandriva/null
No group named 'mandian', will fork to your personal platform
Internal server error: it has returned non-json data.
<html><head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<title>404</title>
<link href='//netdna.bootstrapcdn.com/bootstrap/3.3.6/css/bootstrap.min.css' media="screen" rel="stylesheet" type="text/css">
<style type="text/css">
</style>
</head>
<body>
<noscript>
<div style='font-size: 12px; color: red; font-weight: bold;'>You need javascript to properly use this site</div>
</noscript>
<article >
<div class='row'>
<div class='col-md-6 col-md-offset-3 text-center'>
<div class="all error404">
<h1>Error <span>404</span></h1>
<h2>Page not found</h2>
<p class="pages">
Try to open other pages.
</p>
<p class="search">
Or use the search.
</p>
</div>
</div>
</div>
</article>
</body></html>
First try into abf. I’ve installed with urpmi. I sign up into abf.openmandriva.org. Before this, in command line,
$ abf get scilab
But I messed up with messages I received. I tried again (already signed up at abf.openmandriva.org),
$ abf get scilab
Cloning into ‘scilab’…
Warning: Permanently added the RSA host key for IP address ‘192.30.253.112’ to the list of known hosts.
Permission denied (publickey).
fatal: Could not read from remote repository.
Please make sure you have the correct access rights
and the repository exists.
I’ve sign up at gitHub before doing this at abf. Should I have only one account for both of you just mean there is something I missed when I signed up for abf?
I did the change ssh to https in git_uri in .abfcfg file, as Mandian suggested. It worked fine, scilab was downloaded.
$ abf get scilab
Branch exit is missing, will use HEAD
I noticed, in this case where no src.rpm file is available, the command “abf get scilab” did not help much.
Nothing was installed. Thus, I think I am at the same point where I was before, I have to check for possible patches to be applied, download the newer source and patches, alter scilab.spec manually and then try “abf rpmbuild scilab.spec”. If building requires are not downloaded I will do it also manually and do rpmrebuild scilab.spec.
Thanks, I will remember this when really rebuilding an existing package. However, for scilab, I want a new version update (5.5.2 => 6.0.0), source is different, patches are different. I will use the spec for 5.5.2 as a guide (so as to keep openmandriva signaturure) and everything else I will download from elsewhere. Please, let me know if I should proceed differently.
By now, I’m checking fedora and mageia src.rpm packages.
Almost there! But I would like to minimize mistakes. I’ve noticed the source (scilab tar.gz) from mageia and fedora are binary equal (diff does not see any difference) but the source I’ve downloaded from scilab’s home page, after unzip and tar -zcxf, differs from that in mageia and fedora by about 1MB.
Then, to check for this difference, I’ve compared the extracted directories by diff -r. The result is about 5 times the original sources. A close look at the difference only in the ACKNOWLEDGMENT file shows that they are virtually equal but the scilab’s home page file has a kind of ENTER command ending every single line (^M).
The question is, is there a way to get rid of this endoflline mark or, if not, to see the differences in file ignoring this mark?
However imho fedora spec is not the best for OpenMandriva. You may use it as a guideline for patch and required packages and some other stuff but the way is to get the OpenMandriva spec and to modify it. Also I’d try to build scilab with clang as openmp has been added now.
I found out that some “BuiidRequires” were removed for scilab 6.0 as well as others were added. Thus, in my limited experience/skills, it seemed useful to me to compare the OMV spec for scilab 5 and other distros’ scilab specs for version 6.0.
The --strip-trailing-cr worked fine. Now, the recursive diff between directories (scilab homepage downloaded and mageia’s directories) is just 176KB. However, It did not helped much. I could not find a rosa’s rpm for scilab 6.0.0.
Mandian, if you end up the scilab 6.0.0 build for OMV before I do, I will use it and inspect it to learn more on what I should have done. There are other packages I need and acquiring some experience on building them can help me.
