The software in the eid-mw and eid-viewer packages is used for user identification when you visit a Belgian government website.
When using the firefox browser the Belgium eID add-on has to be installed in firefox to perform the identification on the wbsites. This Belgium eID add-on usses the eid-mw and eid-viewer packages to perform its tasks.
The newest firefox used by OpenMandrivaLx3,03 requests the latest version of the Belgium eID add-on and this add-on needs the latest version of the eid-mw and eid-viewer packages
Question: Is it possible to update the eid-mw and eid-viewer packages in the OpenMandrivaLx3.03 repository?
The installed eid-mw and eid-viewer packages in the OpenMandrivaLx3.03 repository are working fine (I tested them). With the proper card-reader and the viewer I can readout the information on my Belgium ID-card and change the pin-code.
To make it work the following additional packages are needed:
acr38u (64bit)
lib64acr38u0 (64bit)
lib64acr38u-devel.
ccid (64bit)
lib64pcsclite-devel (64bit).
All available in the OpenMandrivaLx3.03 repository.
To identify yourself on a government website via firefox the Belgium eID add-on is needed. I installed it but it complains that eid-mw and eid-viewer are outdated.
This complete set-up works fine under OpenMandrivaLx 2014.2. I still use it.
A Package request bug report is the best way to get a package in need of updating updated. Or to get a new package added to repos. Bug reports are always a better way to get attention of developers than a forum post. A forum post may be seen by devs or it may be missed completely.
FWIW: If I go no IRC and ask developers about things like this (and I do) one of the first questions asked will be where is the bug report?
And so at least one developer did read your post. Glad it worked out this way. Thanks @fedya.
Maybe my statement should change to “If you post in the forum a package or update request and don’t get a response in a few days or a week then file package request bug report”?
I rebooted and connected my usb card reader loaded with my ID card. I started the eid-viewer and was able to read out the card.
Finally I opened firefox and installed the Belgium eID add-on
Note: The add-on has to be configured before it can be used in firefox. The configuration instructions can be found on this URL Log in with eID | eID software
I think this software can be moved to it’s offical location.
