I’m assuming we’re having a TC meeting on Wed. 3/1/2017 at 17:00 CET. Of course we all know what happens when one assumes…
This post is to request that we add to list some discussion about bug reporting tools. As I dig in to this I have so far identified 3 different bug reporting tools. One is the KDE tool which I don’t know how to get to work though I imagine I could if I Googled about it and RTFM. Also there’s ABRT, to my knowledge a Fedora tool, and drakbug a drakxtool. Just would like to discuss about getting one for OpenMandriva to work, I assume that would be either ABRT or drakbug. Also would like to discuss if we should have some dialog window, or notes, or documentation (Release Notes?) about how to use the KDE tool. Or combination thereof? Like a dialog window and something in Release Notes?
There is also a thread about bug reporting tools on Cooker ML (started by me). No promises but maybe by Wednesday I’ll have read up on the KDE bug reporting tool. Is it called something like Dr. Konqi?
Another worthwhile topic for discussion. This is one I recently encountered but don’t know what to do with. What happened was I installed OM Lx 3.01 (.iso build # 720) and updated with standard repos in order to get a representative system of a user using stable .iso and repos only .ie no testing repo packages ever. Or in other words a system like perhaps a majority of users currently have.
What I discovered is that if a user does this, updates system, and reboots then the root and user password (same in this case) are no longer recognized. Needless to say for average users this is a major problem. I would think this to be a bug but don’t really know how to proceed. We have had at least one instance of this reported in forum that I know of in addition to my experience.
maybe build more up the Drakconf with enhanced Configurationstools,
like a Maria/MYSqlDB Easy Databasecreator with IP/Localhost, Name, Passwort for create
a DB and a Simple Backup’er for diffrent Applications and hold it Simple,
Administrate something it is exist with other huge tools, but we need a simple
DB-create tool who it is easy for create short an db for a Webapp like a Forum, Cloud or something
and this in our drakconf center…
An really well working Hosts-editor and hosts file configurator,
because this what at moment works not really well, because we have a:
[blocked domains(spam)] //this maks also possible for blocking spamming domains
127.0.0.1 porn.com porn
127.0.0.1 advertiser.com advertiser
–snap–/etc/hosts----include modifications-----------------------------------
this is normal and not something like it is happend at moment !
For this should create a really well Networkconfiguration
for configuration
for the possible to diffrent Networkcards/connector/virtual hosts configurate
an well (maybe hardcoded) localdomain in ip4 and ip6 and spam-remover in the hostsfile
also configuration the new IP6 correctly include Fullname and alias
and setting up automatically the localdamin in ip4&ip6, this is standart
and could be programmed hard into.
a well subdivision and possible single editing
like add and remove single hosts (hosts only listing)
and a possible for add and remove spammdomains in single edit mode
maby also for adding domains from users and maybe FF-plugins or Crome-plugins
to have a possible for have a API for adding Spamhosts
(maybe can we be the firstwho have some possible)
For handy this whole with a maybe Tabed Surface/Gui for the whole
Networks, in 2-4 modes: Simple,Wlan(Notebook),Enhanced for configuring a Single Networkcard and Extended for enhanced Administrators :
Simple : DHCP autoconnect
Wlan, Roaming
Configuration a Single Networkcard
and Extended for configuring Servers as Administator
with this is it also possible for use this as a Server-Distriebution,
if it possible for Configuring the Networks Stack fully and really without some fail’s in our current hostsfile.
To be this possible do we need a correct, like it was in the old times,
a well configurate hosts-file. This is No1.
a Drakconf Mailserver Configurator Plugin
and a
Drakconf Proxy(&anonymous) Configuration Plugin
Drakconf Bug Subscriber for Admins and a Bugsender
and a Buglisting from own notification (include autoreporter messages of autobugfiler)
(so, a listing of the whole Messages where was sending to issues.openmandriva.org)
to not need ever open the issues Webpage, select the right Distro and so on.
So, make more enhanced and handy the Drakconf to have
a Drakconf who it is easy Possible for configurateing
the Linuxsystem more better.
maybe be i am not there and have not the possible for open my laptop,
because i have to work, but i hope this suggestions be something for our
Distro and helps to be more in demand .
