In a attempt to access an external site in a message at thunderbird, Qupzilla was called. But Qupzilla has problems:
“QOpenGLWidget: Failed to create context
composeAndFlush: makeCurrent() failed”
and do not works.
Now I got to the following problem. I decided to remove qupzilla but task-lxqt requires qupzilla and should be removed too. Ok. I removed task-lxqt and got a long list of lxqt packages + some old kernels + etc that became orphans. The point is that if I try to reinstall only task-lxqt I got another list of packages to install that do not match the first list of orphaned packages.
So this is the question: how could task-lxqt be installed in the first place without the packages that now are required to reinstall it?
Next, the list of orphaned packages when I removed task-lxqt and the list or required packages to reinstall it.
First list;
kernel-release-desktop-4.9.1-4omv-1-1-omv2015.0.x86_64
kernel-release-desktop-4.9.2-1omv-1-1-omv2015.0.x86_64
kernel-release-desktop-4.9.5-1omv-1-1-omv2015.0.x86_64
kernel-release-desktop-devel-4.9.1-4omv-1-1-omv2015.0.x86_64
kernel-release-desktop-devel-4.9.2-1omv-1-1-omv2015.0.x86_64
kernel-release-desktop-devel-4.9.5-1omv-1-1-omv2015.0.x86_64
lib64QupZilla2-2.0.2-1-omv2015.0.x86_64
lib64fm-extra4-1.2.5-1-omv2015.0.x86_64
lib64fm-gtk4-1.2.5-1-omv2015.0.x86_64
lib64fm-qt3-0.11.2-4-omv2015.0.x86_64
lib64fm4-1.2.5-1-omv2015.0.x86_64
lib64imlib2_1-1.4.6-9-omv2015.0.x86_64
lib64imlib2_1-filters-1.4.6-9-omv2015.0.x86_64
lib64imlib2_1-loaders-1.4.6-9-omv2015.0.x86_64
lib64lxqt-globalkeys-ui0-0.11.0-1-omv2015.0.x86_64
lib64lxqt-globalkeys0-0.11.0-1-omv2015.0.x86_64
lib64menu-cache3-1.0.2-6-omv2015.0.x86_64
lib64muparser2-2.2.5-1-omv2015.0.x86_64
lib64obrender32-3.6.1-5-omv2015.0.x86_64
lib64obt2-3.6.1-5-omv2015.0.x86_64
lib64qt5xdg2-2.0.0-1-omv2015.0.x86_64
lib64qtermwidget5_0-0.7.1-1-omv2015.0.x86_64
lib64statgrab6-0.17-14-omv2015.0.x86_64
lib64sysstat-qt5_0-0.3.3-1-omv2015.0.x86_64
libfm-1.2.5-1-omv2015.0.x86_64
lxmenu-data-0.1.5-1-omv2015.0.noarch
lxqt-about-0.11.0-2-omv2015.0.x86_64
lxqt-admin-0.11.0-1-omv2015.0.x86_64
lxqt-common-0.11.1-1-omv2015.0.noarch
lxqt-config-0.11.0-3-omv2015.0.x86_64
lxqt-globalkeys-0.11.0-1-omv2015.0.x86_64
lxqt-l10n-0.11.1-3-omv2015.0.noarch
lxqt-notificationd-0.11.0-1-omv2015.0.x86_64
lxqt-openssh-askpass-0.11.0-1-omv2015.0.x86_64
lxqt-panel-0.11.0-3-omv2015.0.x86_64
lxqt-powermanagement-0.11.0-1-omv2015.0.x86_64
lxqt-qtplugin-0.11.1-1-omv2015.0.x86_64
lxqt-runner-0.11.0-1-omv2015.0.x86_64
lxqt-session-0.11.0-2-omv2015.0.x86_64
lxqt-sudo-0.11.0-1-omv2015.0.x86_64
menu-cache-1.0.2-6-omv2015.0.x86_64
obconf-qt-0.11.1-2-omv2015.0.x86_64
openbox-3.6.1-5-omv2015.0.x86_64
pavucontrol-qt-0.2.0-1-omv2015.0.x86_64
pcmanfm-qt-0.11.2-2-omv2015.0.x86_64
qterminal-0.7.1-1-omv2015.0.x86_64
qtermwidget-0.7.1-1-omv2015.0.x86_64
system-tools-backends2-2.10.2-6-omv2015.0.x86_64
Second list,
lib64mikmod3 3.3.7 3 omv 2015.0 x86_64 (suggested)
lib64qtkeychain0 0.6.2 1 omv 2015.0 x86_64 (suggested)
lib64revenge-stream0.0_0 0.0.4 1 omv 2015.0 x86_64 (suggested)
lib64wordnet3.0 3.0 23 omv 2015.0 x86_64 (suggested)
lib64yajl2 2.0.4 9 omv 2015.0 x86_64 (suggested)
lib64zziplib0 0.13.62 4 omv 2015.0 x86_64 (suggested)
mpd 0.19.17 1 omv 2015.0 x86_64 (suggested)
notepadqq 0.50.4 6 omv 2015.0 x86_64 (suggested)
qtkeychain-common 0.6.2 1 omv 2015.0 x86_64 (suggested)
taglib-extras 1.0.1 15 omv 2015.0 x86_64 (suggested)
trojita 0.6 1 omv 2015.0 x86_64 (suggested)
wordnet 3.0 23 omv 2015.0 x86_64 (suggested)
(mídia “main updates”)
calligra 3.0.0 1 omv 2015.0 x86_64 (suggested)
calligra-core 3.0.0 1 omv 2015.0 x86_64 (suggested)
calligra-flow 3.0.0 1 omv 2015.0 x86_64 (suggested)
calligra-karbon 3.0.0 1 omv 2015.0 x86_64 (suggested)
calligra-sheets 3.0.0 1 omv 2015.0 x86_64 (suggested)
calligra-stage 3.0.0 1 omv 2015.0 x86_64 (suggested)
calligra-words 3.0.0 1 omv 2015.0 x86_64 (suggested)
lib64RtfReader15 3.0.0 1 omv 2015.0 x86_64 (suggested)
lib64basicflakes15 3.0.0 1 omv 2015.0 x86_64 (suggested)
lib64calligrasheetscommon15 3.0.0 1 omv 2015.0 x86_64 (suggested)
lib64calligrasheetsodf15 3.0.0 1 omv 2015.0 x86_64 (suggested)
lib64calligrastageprivate15 3.0.0 1 omv 2015.0 x86_64 (suggested)
lib64flake15 3.0.0 1 omv 2015.0 x86_64 (suggested)
lib64karboncommon15 3.0.0 1 omv 2015.0 x86_64 (suggested)
lib64karbonui15 3.0.0 1 omv 2015.0 x86_64 (suggested)
lib64koformula15 3.0.0 1 omv 2015.0 x86_64 (suggested)
lib64komain15 3.0.0 1 omv 2015.0 x86_64 (suggested)
lib64komsooxml15 3.0.0 1 omv 2015.0 x86_64 (suggested)
lib64koodf15 3.0.0 1 omv 2015.0 x86_64 (suggested)
lib64koodf2_15 3.0.0 1 omv 2015.0 x86_64 (suggested)
lib64koodfreader15 3.0.0 1 omv 2015.0 x86_64 (suggested)
lib64kopageapp15 3.0.0 1 omv 2015.0 x86_64 (suggested)
lib64koplugin15 3.0.0 1 omv 2015.0 x86_64 (suggested)
lib64kostore15 3.0.0 1 omv 2015.0 x86_64 (suggested)
lib64kotext15 3.0.0 1 omv 2015.0 x86_64 (suggested)
lib64kotextlayout15 3.0.0 1 omv 2015.0 x86_64 (suggested)
lib64kovectorimage15 3.0.0 1 omv 2015.0 x86_64 (suggested)
lib64koversion15 3.0.0 1 omv 2015.0 x86_64 (suggested)
lib64kowidgets15 3.0.0 1 omv 2015.0 x86_64 (suggested)
lib64kowidgetutils15 3.0.0 1 omv 2015.0 x86_64 (suggested)
lib64kowv2_9 3.0.0 1 omv 2015.0 x86_64 (suggested)
lib64kundo2_15 3.0.0 1 omv 2015.0 x86_64 (suggested)
lib64phonon4qt5experimental4 4.9.0 3 omv 2015.0 x86_64 (suggested)
lib64pigmentcms15 3.0.0 1 omv 2015.0 x86_64 (suggested)
lib64wordsprivate15 3.0.0 1 omv 2015.0 x86_64 (suggested)
lximage-qt 0.5.1 1 omv 2015.0 x86_64 (suggested)
qupzilla 2.0.2 1 omv 2015.0 x86_64
qupzilla-core 2.0.2 1 omv 2015.0 x86_64
qupzilla-plugins 2.0.2 1 omv 2015.0 x86_64
task-lxqt 0.11.0 3 omv 2015.0 noarch
(mídia “contrib”)
cantata 2.0.1 1 omv 2015.0 x86_64 (suggested)
(mídia “restricted”)
lame 3.99.5 10 omv 2015.0 x86_64 (suggested)
lib64lame0 3.99.5 10 omv 2015.0 x86_64 (suggested)
