Systemd-doc-236-1 conflicts with lib64udev-devel
This was reported by @albpanig and I have confirmed in VBox:
A requested package cannot be installed:
systemd-doc-236-1-omv2015.0.x86_64 (due to conflicts with lib64udev-devel-236-1-omv2015.0.x86_64)
Continue installation anyway? (Y/n)
Workaround:
# urpmi lib64udev-devel
then:
# urpmi --auto-update
Edit: I can file a bug report if needed.
Can you please provide more logs ?
Just tried to install it on an updated system and nothing came wrong.
Last update was on Jan, 1st.
Here, I have almost the same but updating complains also also about a i586 version of systemd-doc, even having system-doc x86_doc already installed and up to date:
Some requested packages cannot be installed:
systemd-doc-236-1-omv2015.0.i586 (due to conflicts with lib64udev-devel-236-1-omv2015.0.x86_64)
What seems weird is that system-doc x86_64 is already installed:
urpmi systemd-doc
(urpmi:5420): Gtk-WARNING **: Unable to locate theme engine in module_path: "adwaita",
Package systemd-doc-236-1-omv2015.0.x86_64 is already installed
When I updated systemd today, systemd-doc was updated then removed. I was able to add it just now:
sudo urpmi systemd-doc
Package systemd-locale-236-2-omv2015.0.x86_64 is already installed
Marking systemd-locale as manually installed, it won’t be auto-orphaned
Marking systemd-doc as manually installed, it won’t be auto-orphaned
writing /var/lib/rpm/installed-through-deps.list
http://abf-downloads.openmandriva.org/3.0/repository/x86_64/main/testing/systemd-doc-236-2-omv2015.0.x86_64.rpm
The following package has bad signature:
/var/cache/urpmi/rpms/systemd-doc-236-2-omv2015.0.x86_64.rpm: Medium without key (OK (RSA/SHA1, Tue 02 Jan 2018 08:50:42 AM EST, Key ID 180922d8bf81de15))
Do you want to continue installation ? (y/N) y
installing systemd-doc-236-2-omv2015.0.x86_64.rpm from /var/cache/urpmi/rpms
Preparing… ########################################################################################
1/1: systemd-doc
Chris
Problem was in one lxqt “noarch” package which required arch specific library. That’s why on x86_64 some i586 packages were about to be installed.
@TPG: this means all “noarch” packages requiring an arch specific package should never be “noarch” package as a rule?
@mandian This means someone made a mistake and added arch specific requires to noarch package :smiley:
Found yet another issue which finally solve this problem:
Now, with the new systemd 236 - 5, systemd was updated. Then, after restarting urpmi, more packages are to be updated but (I’ve made a free translation),
This package cannot be installed:
lib64udev-devel-231-1-omv2015.0.x86_64 (because is lacking lib64udev1[== 231-1:2015.0])
Why would it be needed to have lib64udev1-231-1? Let me add that,
$ rpm -qa|grep lib64udev
lib64udev1-234-2-omv2015.0.x86_64
I saw same thing so I know it’s true. But it is kind of funny too. Calling for such an old packages instead of current version. I’m sure there is a reason.
Hard to say, why have you installed it. Please run urpme lib64udev-devel
I don’t have a lib64udev-devel. Did you mean " urpme lib64udev1"?
I also saw this message before. If I remember well, I manually installed lib64udev-devel-236-5:2015.0, then the update went well.
If I remove it (without any deps warning), I can see both packages (231 & 236) available with the first one (231) marked as ready for update in rpmdrake. That might explain why the conflict happens.
A vexing issue.
And like a bad cold it seems like it just won’t go away. (Dag nab it!) :roll_eyes:
Does this issue still exist ?
If yes, please attach here output of urpmi --auto-update --debug
Yes, the issue exists, it follows the urpmi --debug output.output_urpmi_debug.txt (13,8 KB)
Thanks @adelson.oliveira for the logs. Now things are clear.
systemd-236 provides new subpackage systemd-doc while old libudev-devel obsoletes systemd-doc package. Kinda crazy, but i may have fixed it with systemd-236-7.
I’ve updated systemd to the new 236-8. But no luck. The problem is still there.
The new output of urpmi --debug --auto-update is,
output_urpmi_debug.txt (14,0 KB)
