Ok I was updating my base system not yet a new install.
And I forgot to mention that I was in a fresh install, fully updated except for the systemd packages. Installed from ISO # 1510.
FWIW: Once I got the systemd-235 install fixed system boots without issue. I did while I was in chroot run --replacepkgs and reinstall all of the systemd-235 packages just to be sure nothing was missed.
Ben christannâs update crashed X too he is all Intel as I think you are. My box is AMD
Didnât Intel used to be a good brand? Kidding, I think.
My update crashed on 2 intel boxes. One with intel graphics and one with ATI.
We canât ship the isoâs with 235 unless we release it into the updates repo which means then we will start breaking peoples boxes.
Ben your crash was quite serious and required post boot intervention; we canât be having that.
Thatâs why I said in another thread âIâm in agreement with Colin, no blockers other than systemd-235.â
Edit: And as said in that thread fixing it is to much for regular users to be expected to do.
Guys can you please make sure you first updated glib to 2.26-10 then run systemd update.
I need to be sure that issue is related to systemd package and not anything else.
I have been installing all other packages first before installing systemd-235.
Ben can you please provide logs?
Yes, Iâll have to reproduce the problem but I can do. Iâm guessing we want Xorg, journalctl, and the xorg.session.log. It seems like Xorg.0.log and xorg.session.log are similar or are they? That question is just for my training and education. Iâll post both.
May not get these done till tomorrow AM.
Um, I have a system installed on hardware ready to install the systemd-235 packages and when I attempted to install them I find they arenât there (main-testing) any longer. Anyway I have a hardware system ready to test install these and gather logs.
On a positive note the main-testing repo obviously got cleaned up which was much needed.
Beware: when my PC updated systemd to version 235-5, the screen went black, and I had to reboot and complete the update by hand.
Chris
Yes it still does changes the hostnameâŚ
I had same type of crash with rapidly flashing screen and have to force reboot. Same behavior as before.
I did check hostname before install of systemd-235 and after reboot and it was not changed. Is it maybe changing hostname when I install it then hostname is changes back to whatâs in /etc/hostname when I reboot?
Iâve set hostname to âopenmandrivaâ everywere it is possible, added traces and now i can say this does not trigger sddm to flash.
Something revokes sddm authorization to Xserver. You can see it in logs.
Oct 23 17:05:16 openmandriva sddm[3991]: /usr/bin/xauth: (stdin):1: bad "remove" command line
Oct 23 17:05:16 openmandriva sddm[3991]: /usr/bin/xauth: (stdin):2: bad "add" command line
Yes, that has been the error from since this first reported. From yesterdays attempt that sequence is repeated over and over like that is exactly what is flashing, it disconnects, reconnects, disconnects, reconnects, and so on:
Nov 02 18:55:16 ben79-pc sddm[4542]: /usr/bin/xauth: (stdin):1: bad "remove" command line
Nov 02 18:55:16 ben79-pc sddm[4542]: /usr/bin/xauth: (stdin):2: bad "add" command line
Nov 02 18:55:16 ben79-pc sddm[4542]: QProcess: Destroyed while process ("/usr/libexec/sddm-helper") is still running.
Nov 02 18:55:16 ben79-pc acpid[3863]: client 9785[0:0] has disconnected
Nov 02 18:55:16 ben79-pc acpid[3863]: client connected from 9800[0:0]
Nov 02 18:55:16 ben79-pc acpid[3863]: 1 client rule loaded
Nov 02 18:55:16 ben79-pc acpid[3863]: client 9800[0:0] has disconnected
Nov 02 18:55:16 ben79-pc acpid[3863]: client connected from 9815[0:0]
This is repeated approximately 6000 or so lines in journalctl log.
Ok with dbus-1.12.2 this issue does not exist.
Can you please confirm ?
Steps to reproduce
- update system, make sure you are running dbus-1.12.2 and sddm-0.16.0-4
- urpmi.addmedia SYSTEMD http://abf-downloads.openmandriva.org/3.0/container/126098/x86_64/main/release/
- urpmi --auto-update --media SYSTEMD
- confirm installing systemd-235
- Observe if sddm acts strange ?
sudo urpmi.addmedia SYSTEMD http://abf-downloads.openmandriva.org/3.0/container/126098/x86_64/main/release/
[sudo] password for colin:
adding medium âSYSTEMDâ
http://abf-downloads.openmandriva.org/3.0/container/126098/x86_64/main/release/media_info/20171102-080425-synthesis.hdlist.cz
[colin@itchka64 ~]$ urpmi --auto-update --media SYSTEMD
(urpmi:6753): Gtk-WARNING **: Unable to locate theme engine in module_path: âadwaitaâ,
medium âSYSTEMDâ is up-to-date
detecting looping forever while trying to resolve dependancies.
Aborting⌠Try again with â-vv --debugâ options at /usr/lib/perl5/vendor_perl/5.20.3/x86_64-linux-thread-multi/URPM/Resolve.pm line 1381.
upmi is not happy
So lets try
urpmi --auto-update
(urpmi:6784): Gtk-WARNING **: Unable to locate theme engine in module_path: âadwaitaâ,
medium âmainâ is up-to-date
medium âmain updatesâ is up-to-date
medium âMain32â is up-to-date
medium âMain32 Updatesâ is up-to-date
medium âcontribâ is up-to-date
medium âcontrib updatesâ is up-to-date
medium âcontrib32â is up-to-date
medium âcontrib32 updatesâ is up-to-date
medium ânon-freeâ is up-to-date
http://abf-downloads.openmandriva.org/3.0/repository/x86_64/media/non-free/updates/media_info/20171117-210621-synthesis.hdlist.cz
updated medium ânon-free updatesâ
medium âNon-free32â is up-to-date
medium âNon-free32 Updatesâ is up-to-date
medium ârestrictedâ is up-to-date
medium ârestricted updatesâ is up-to-date
medium âmain32â is up-to-date
medium âmain_testingâ is up-to-date
medium âcontrib_testingâ is up-to-date
medium âcontrib_testing32â is up-to-date
medium ârestricted_testingâ is up-to-date
medium ânon-free_testingâ is up-to-date
GOT: kernel-rc-desktop-4.6.0-0.rc7.1omv-1-1-omv2015.0.x86_64
GOT: kernel-rc-server-4.6.0-0.rc7.1omv-1-1-omv2015.0.x86_64
GOT: kernel-release-desktop-4.6.5-2omv-1-1-omv2015.0.x86_64
GOT: kernel-release-server-4.6.5-2omv-1-1-omv2015.0.x86_64
GOT: kernel-release-server-4.13.12-2omv-1-1-omv2015.0.x86_64
GOT: kernel-release-desktop-4.13.11-2omv-1-1-omv2015.0.x86_64
GOT: kernel-release-server-4.13.11-2omv-1-1-omv2015.0.x86_64
GOT: kernel-release-server-4.13.12-1omv-1-1-omv2015.0.x86_64
In order to satisfy the âkernel-rc-desktop-4.6.0-0.rc7.1omv|kernel-rc-server-4.6.0-0.rc7.1omv|kernel-release-desktop-4.6.5-2omv|kernel-release-server-4.6.5-2omv|kernel-release-server-4.13.12-2omv|kernel-release-desktop-4.6.5-2omv|kernel-rc-desktop-4.6.0-0.rc7.1omv|kernel-release-desktop-4.13.12-2omv|kernel-release-desktop-4.13.11-2omv|kernel-release-server-4.13.11-2omv|kernel-release-server-4.13.12-1omvâ dependency, one of the following packages is needed:
1- kernel-rc-desktop-4.6.0-0.rc7.1omv-1-1-omv2015.0.x86_64: Linux Kernel for desktop use with x86_64 (to install)
2- kernel-rc-server-4.6.0-0.rc7.1omv-1-1-omv2015.0.x86_64: Linux Kernel for server use with x86_64 (to install)
3- kernel-release-desktop-4.6.5-2omv-1-1-omv2015.0.x86_64: Linux Kernel for desktop use with x86_64 (to install)
4- kernel-release-server-4.6.5-2omv-1-1-omv2015.0.x86_64: Linux Kernel for server use with x86_64 (to install)
5- kernel-release-server-4.13.12-2omv-1-1-omv2015.0.x86_64: Linux Kernel for server use with x86_64 (to install)
6- kernel-release-desktop-4.13.11-2omv-1-1-omv2015.0.x86_64: Linux Kernel for desktop use with x86_64 (to install)
7- kernel-release-server-4.13.11-2omv-1-1-omv2015.0.x86_64: Linux Kernel for server use with x86_64 (to install)
8- kernel-release-server-4.13.12-1omv-1-1-omv2015.0.x86_64: Linux Kernel for server use with x86_64 (to install)
What is your choice? (1-8)
Not sure this is what is supposed to happen.
uname -a
Linux itchka64 4.13.12-desktop-2omv #1 SMP Tue Nov 14 14:40:28 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
Colin
