I installed open mandriva rome a few days ago on a an empty hard drive. When I click “Sleep” in the “start” menu, my computer goes to sleep. When it is asleep, when I press a button on the keyboard, it starts up, I hear fans spinning, but the screen remains black and the display says “no signal”. The only way to make computer work after that is to hold the turn off button and then turn it on again.
I saw on the forums posts about sleep does not working, but i don’t know what I should do, especially, since it’s a fresh installation. Please advise.
I have checked the Resources category (Resources Index )
KDE
The computer does not wake up from sleep.
engine
April 28, 2026, 1:11pm
2
Are You using any nvidia gpu and driver?
yes I installed Nvidia driver from the “welcome” program.
engine
April 28, 2026, 4:05pm
4
Check if nvidia deamons are enabled on your system:
[engine@engine-om ~]$ systemctl status nvidia-suspend
○ nvidia-suspend.service - NVIDIA system suspend actions
Loaded: loaded (/usr/lib/systemd/system/nvidia-suspend.service; enabled; preset: disabled)
└─10-timeout-abort.conf
Active: inactive (dead)
If not, you can enable it with: sudo systemctl enable nvidia-suspend
The same for hibernation:
[engine@engine-om ~]$ systemctl status nvidia-hibernate
○ nvidia-hibernate.service - NVIDIA system hibernate actions
Loaded: loaded (/usr/lib/systemd/system/nvidia-hibernate.service; enabled; preset: disabled)
If not, you can enable it with: sudo systemctl enable nvidia-hibernate
As far as I remember they are disabled by default.
I ran it and now sleep works, thank you.
sadly, after restart it stopped working again.
system
(system)
Closed
May 16, 2026, 10:08pm
7
