Then after getiing Skrooge to open it publishes the error:
Loading plugin Skrooge operation plugin failed because the factory could not be found in skrooge_operation: Cannot load library /usr/lib64/qt5/plugins/skrooge_operation.so: (libskgbankgui.so.2: cannot open shared object file: No such file or directory)
Loading plugin Skrooge report plugin failed because the factory could not be found in skrooge_report: Cannot load library /usr/lib64/qt5/plugins/skrooge_report.so: (libskgbankgui.so.2: cannot open shared object file: No such file or directory)
Loading plugin Skrooge budget plugin failed because the factory could not be found in skrooge_budget: Cannot load library /usr/lib64/qt5/plugins/skrooge_budget.so: (libskgbankgui.so.2: cannot open shared object file: No such file or directory)
Loading plugin Skrooge unit plugin failed because the factory could not be found in skrooge_unit: Cannot load library /usr/lib64/qt5/plugins/skrooge_unit.so: (libskgbankgui.so.2: cannot open shared object file: No such file or directory)
Loading plugin Skrooge payee plugin failed because the factory could not be found in skrooge_payee: Cannot load library /usr/lib64/qt5/plugins/skrooge_payee.so: (libskgbankgui.so.2: cannot open shared object file: No such file or directory)
Loading plugin Skrooge calculator plugin failed because the factory could not be found in skrooge_calculator: Cannot load library /usr/lib64/qt5/plugins/skrooge_calculator.so: (libskgbankgui.so.2: cannot open shared object file: No such file or directory)
Loading plugin Skrooge categories plugin failed because the factory could not be found in skrooge_categories: Cannot load library /usr/lib64/qt5/plugins/skrooge_categories.so: (libskgbankgui.so.2: cannot open shared object file: No such file or directory)
Loading plugin Skrooge scheduled plugin failed because the factory could not be found in skrooge_scheduled: Cannot load library /usr/lib64/qt5/plugins/skrooge_scheduled.so: (libskgbankgui.so.2: cannot open shared object file: No such file or directory)
Loading plugin Skrooge bank plugin failed because the factory could not be found in skrooge_bank: Cannot load library /usr/lib64/qt5/plugins/skrooge_bank.so: (libskgbankgui.so.2: cannot open shared object file: No such file or directory)
Loading plugin Skrooge tracker plugin failed because the factory could not be found in skrooge_tracker: Cannot load library /usr/lib64/qt5/plugins/skrooge_tracker.so: (libskgbankgui.so.2: cannot open shared object file: No such file or directory)
Loading plugin Skrooge search plugin failed because the factory could not be found in skrooge_search: Cannot load library /usr/lib64/qt5/plugins/skrooge_search.so: (libskgbankgui.so.2: cannot open shared object file: No such file or directory)
