on 4.2 KDE plasma install goes good then when I switch to rolling and run updates they go good also until i reboot then I get a pop up before log in saying
‘configuration file “var/lib/sddm/.config/sddm-greeterrc” not writable. please contact your system administrator.’ and my login password doesn’t work anymore…can’t figure out what I’m doing wrong… I appreciate the help…
hi, thank you…i reinstalled it now everything works…
