In my continuing hunt for the bug with the standalone version of Calamares I wondered whether teh problem had anything to do with squashfs. After a bit of hunting around I cam across this page Squashfs Performance Testing – Jonathan Carter Which contains some simple scripts to test the efficiency of the various compression types available in mksquashfs as well as the effect of blocksize. I have been wondering whether all the toubles with the install part of the ISO may be due to the slowness of unsquashfs since adding delays in the scripts did seem to help the issue.
The results of the tests are very revealing hence my post here.
They would argue for a change in how we create the squashfs filesystems for our isos.
The left hand column shows both the type of compression and the blocksize the rest is self explanatory.
The script decompresses the original filesystem and then recompresses it hence the varying inital sizes.
For reference our settings are those in bold italic.
These tests were run on my local 8 cpu AMD with 16Gig RAM
The memory throughput is:-
dd if=/dev/zero of=/dev/null bs=1M count=100000
100000+0 records in
100000+0 records out
104857600000 bytes (105 GB, 98 GiB) copied, 7.46942 s, 14.0 GB/s
Filename Size Ratio CTIME UTIME
squashfs-gzip-4096.squashfs 2408360 42.17% 0m44.844s 1m26.626s
squashfs-gzip-8192.squashfs 2299960 40.29% 0m52.296s 1m11.806s
squashfs-gzip-16384.squashfs 2222788 38.95% 1m10.460s 1m11.559s
squashfs-gzip-32768.squashfs 2164848 37.94% 1m32.189s 1m46.050s
squashfs-gzip-65536.squashfs 2124288 37.23% 1m52.192s 1m48.464s
squashfs-gzip-131072.squashfs 2102304 36.85% 2m45.725s 1m50.582s
squashfs-lzo-4096.squashfs 2704312 47.35% 4m44.273s 1m10.986s
squashfs-lzo-8192.squashfs 2580616 45.21% 7m42.889s 0m53.958s
squashfs-lzo-16384.squashfs 2483156 43.51% 4m5.703s 0m55.145s
squashfs-lzo-32768.squashfs 2402196 42.10% 5m41.550s 1m8.597s
squashfs-lzo-65536.squashfs 2335468 40.94% 6m18.788s 1m1.768s
squashfs-lzo-131072.squashfs 2295204 40.23% 3m56.797s 1m0.462s
squashfs-xz-4096.squashfs 2334384 40.88% 7m14.503s 3m55.037s
squashfs-xz-8192.squashfs 2162352 37.88% 6m26.875s 3m44.205s
squashfs-xz-16384.squashfs 2039460 35.74% 5m9.183s 3m41.578s
squashfs-xz-32768.squashfs 1947760 34.14% 7m4.122s 3m55.465s
squashfs-xz-65536.squashfs 1877668 32.91% 5m34.739s 4m13.721s
squashfs-xz-131072.squashfs 1822024 31.94% 4m50.316s 5m13.156s
