Rebuild an check depencies - cooker repo
have theses errors for upgrade
OpenMandriva Cooker - x86_64        8.5 kB/s | 1.5 kB     00:00
digikam.x86_64        2:6.0.0-1        cooker-x86_64
showfoto.x86_64        2:6.0.0-1        cooker-x86_64
Passage de paquets en obsolètes
kget.x86_64        19.04.1-1        @cooker-x86_64
lib64kgetcore5.x86_64        19.04.1-1        @cooker-x86_64
Erreur :
 Problème 1: package lib64opencv_features2d3.4-3.4.5-1.x86_64 requires lib64opencv_calib3d3.4 = 3.4.5-1, but none of the providers can be installed
  - package digikam-2:6.0.0-1.x86_64 requires libopencv_features2d.so.3.4()(64bit), but none of the providers can be installed
  - cannot install both lib64opencv_calib3d3.4-3.4.5-1.x86_64 and lib64opencv_calib3d3.4-3.4.5-2.x86_64
  - cannot install the best update candidate for package digikam-6.1.0-2.x86_64
  - problem with installed package lib64opencv_calib3d3.4-3.4.5-2.x86_64
 Problème 2: package digikam-2:6.0.0-1.x86_64 requires libopencv_features2d.so.3.4()(64bit), but none of the providers can be installed
  - package lib64opencv_features2d3.4-3.4.5-1.x86_64 requires lib64opencv_core3.4 = 3.4.5-1, but none of the providers can be installed
  - package showfoto-2:6.0.0-1.x86_64 requires digikam = 2:6.0.0-1, but none of the providers can be installed
  - cannot install both lib64opencv_core3.4-3.4.5-1.x86_64 and lib64opencv_core3.4-3.4.5-2.x86_64
  - cannot install the best update candidate for package showfoto-6.1.0-2.x86_64
I solved by removing digikam, and re-installing it (digikam and showfoto IIRC).
