Problem: conflicting requests libprotobuf-lite.so24()(64bit)
6.6.2-desktop-1omv2390 #1 SMP PREEMPT_DYNAMIC Mon Nov 20 19:43:20 UTC 2023 x86_64 x86_64 x86_64 GNU/Linux
When I try to install Mixxx (mixxx.org) I get the message:
  • nothing provides libprotobuf-lite.so24()(64bit)
    -needed by mixxx-2.3.6-1.x86_64 from rock-x86_64-unsupported
I’m tried:
sudo dnf clean all && dnf update
rpm -qa | grep dnf
python-dnfdaemon-0.3.22-1.noarch
lib64dnf2-0.72.0-3.x86_64
python-libdnf-0.72.0-3.x86_64
python-dnf-4.18.1-1.noarch
dnf-4.18.1-1.noarch
python-dnf-plugins-core-4.4.3-1.noarch
python-dnf-plugins-extras-common-4.1.1-1.noarch
dnf-automatic-4.18.1-1.noarch
dnfdragora-2.1.4-1.x86_64
python-dnf-plugin-rpmconf-4.1.1-1.noarch
dnf-data-4.18.1-1.noarch
I have the package installed on lib64protobuf-lite 25.1
@Stan thanks for reporting. mixxx package was rebuilt for Rock/5.0. Now it will install here in VBox test machine. Do not know if it works.
sudo dnf in mixxx --refresh
or
sudo dnf up mixxx --refresh
Thanks You Ben for your support.
Mixxx has been innstalled, but not running;
[stanislaw@stkorek ~]$ mixxx
Warning [Main]: Failed to load "qt" translations for locale "pl_PL" from "/usr/share/mixxx/translations/"
ALSA lib /builddir/build/BUILD/alsa-lib-1.2.10/src/pcm/pcm.c:2675:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib /builddir/build/BUILD/alsa-lib-1.2.10/src/pcm/pcm.c:2675:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib /builddir/build/BUILD/alsa-lib-1.2.10/src/pcm/pcm.c:2675:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib /builddir/build/BUILD/alsa-lib-1.2.10/src/pcm/pcm_route.c:878:(find_matching_chmap) Found no matching channel map
Expression 'alsa_snd_pcm_hw_params_set_buffer_size_near( pcm, hwParams, &alsaBufferFrames )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 922
ALSA lib /builddir/build/BUILD/alsa-plugins-1.2.7.1/oss/pcm_oss.c:397:(_snd_pcm_oss_open) Cannot open device /dev/dsp
ALSA lib /builddir/build/BUILD/alsa-lib-1.2.10/src/confmisc.c:160:(snd_config_get_card) Invalid field card
ALSA lib /builddir/build/BUILD/alsa-plugins-1.2.7.1/usb_stream/pcm_usb_stream.c:482:(_snd_pcm_usb_stream_open) Invalid card 'card'
Cannot connect to server socket err = Nie ma takiego pliku ani katalogu
Cannot connect to server request channel
jack server is not running or cannot be started
JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
Warning [Main]: ControlDoublePrivate::getControl returning NULL for ( "[Master]" , "skin_settings" )
Warning [Main]: ControlDoublePrivate::getControl returning NULL for ( "[Microphone]" , "show_microphone" )
Warning [Main]: ControlDoublePrivate::getControl returning NULL for ( "[VinylControl]" , "show_vinylcontrol" )
Warning [Main]: ControlDoublePrivate::getControl returning NULL for ( "[PreviewDeck]" , "show_previewdeck" )
Warning [Main]: ControlDoublePrivate::getControl returning NULL for ( "[Library]" , "show_coverart" )
Warning [Main]: ControlDoublePrivate::getControl returning NULL for ( "[Master]" , "maximize_library" )
Memory protection violation (memory dump)
Please file a bug report. Include steps to reproduce the problem in Rock/5.0 and the omv bug report log:
Ben, thanks for your quick reply.
I have a problem because my BUG-REPORT TOOL does not generate a log file.
The Bug Report Tool in OM-Welcome should create a file in your /home/your_user_name directory. You should have been asked to enter root password.
Running in Konsole:
sudo sh omv-bug-report.sh
Will also generate the bug report.
There is a more recent version of mixxx in ROME that appears to work:
The packages in ROME are supposed to become Rock/5.1 and Rock/6.0 soonish. If anyone does any fresh installs please install Plama6 not Plasma5. Plasma5 is EOL and the packages are going to be removed from cooker and rolling repos soonish. Remember soon is a very flexible concept in small groups like OM. My hope is soonish means a few weeks.
Hello Ben,
As I wrote earlier, after starting the Bug Report Tool I was asked to enter the SU password.
After entering the password I received a message about generating a log file in \home"user" but there was nothing in the specified directory.
The file was generated after entering the command:
https://github.com/user-attachments/files/18186630/omdv-bug-report-20241218180112.log
Thank You.
