Packages systemd (stack), lib64gck1_0, and lib64gcr-base3_1 have Invalid key (aka: Bad signature)
I updated like this:
# urpmi --clean -av
cleaning /var/cache/urpmi/partial and /var/cache/urpmi/rpms
# urpmi -v --auto-update
 Package                                   Version      Release       Dist  DEpoch Arch
(medium "main updates")
 cpupower                                  4.15.12      1             omv   2015.0 x86_64
 kernel-release-desktop-4.15.12-1omv       1            1             omv   2015.0 x86_64
 kernel-release-desktop-devel-4.15.12-1omv 1            1             omv   2015.0 x86_64
 kernel-release-desktop-devel-latest       4.15.12      1             omv   2015.0 x86_64
 kernel-release-desktop-latest             4.15.12      1             omv   2015.0 x86_64
 kernel-release-headers                    4.15.12      1             omv   2015.0 x86_64
 lib64gck1_0                               3.28.0       1             omv   2015.0 x86_64
 lib64gcr-base3_1                          3.28.0       1             omv   2015.0 x86_64
(medium "restricted updates")
 lib64dvdcss2                              1.4.1        1             omv   2015.0 x86_64
104MB of additional disk space will be used.
68MB of packages will be retrieved.
Proceed with the installation of the 9 packages? (Y/n) Y
The following packages have bad signatures:
/var/cache/urpmi/rpms/lib64gck1_0-3.28.0-1-omv2015.0.x86_64.rpm: Invalid Key ID (OK (RSA/SHA1, Tue 27 Mar 2018 04:32:37 AM CDT, Key ID 0e088bc96e882519))
/var/cache/urpmi/rpms/lib64gcr-base3_1-3.28.0-1-omv2015.0.x86_64.rpm: Invalid Key ID (OK (RSA/SHA1, Tue 27 Mar 2018 04:32:37 AM CDT, Key ID 0e088bc96e882519))
So we can see that the packages with Invalid key are in main-updates repo. There are no testing repos on this system.
Here, first update in a fresh 1915 build install:
I seguenti pacchetti hanno delle firme errate:
/var/cache/urpmi/rpms/lib64gck1_0-3.28.0-1-omv2015.0.x86_64.rpm: Key ID (OK (RSA/SHA1, mar 27 mar 2018 11:32:37 CEST, Key ID 0e088bc96e882519)) non valida
/var/cache/urpmi/rpms/lib64gcr-base3_1-3.28.0-1-omv2015.0.x86_64.rpm: Key ID (OK (RSA/SHA1, mar 27 mar 2018 11:32:37 CEST, Key ID 0e088bc96e882519)) non valida
/var/cache/urpmi/rpms/lib64nss_myhostname2-238-2-omv2015.0.x86_64.rpm: Key ID (OK (RSA/SHA1, sab 24 mar 2018 01:48:14 CET, Key ID 64aca0ca954d98c5)) non valida
/var/cache/urpmi/rpms/lib64nss_resolve2-238-2-omv2015.0.x86_64.rpm: Key ID (OK (RSA/SHA1, sab 24 mar 2018 01:48:15 CET, Key ID 64aca0ca954d98c5)) non valida
/var/cache/urpmi/rpms/lib64nss_systemd2-238-2-omv2015.0.x86_64.rpm: Key ID (OK (RSA/SHA1, sab 24 mar 2018 01:48:15 CET, Key ID 64aca0ca954d98c5)) non valida
/var/cache/urpmi/rpms/lib64systemd0-238-2-omv2015.0.x86_64.rpm: Key ID (OK (RSA/SHA1, sab 24 mar 2018 01:48:14 CET, Key ID 64aca0ca954d98c5)) non valida
/var/cache/urpmi/rpms/lib64udev1-238-2-omv2015.0.x86_64.rpm: Key ID (OK (RSA/SHA1, sab 24 mar 2018 01:48:15 CET, Key ID 64aca0ca954d98c5)) non valida
/var/cache/urpmi/rpms/systemd-238-2-omv2015.0.x86_64.rpm: Key ID (OK (RSA/SHA1, sab 24 mar 2018 01:47:57 CET, Key ID 64aca0ca954d98c5)) non valida
/var/cache/urpmi/rpms/systemd-bash-completion-238-2-omv2015.0.x86_64.rpm: Key ID (OK (RSA/SHA1, sab 24 mar 2018 01:48:15 CET, Key ID 64aca0ca954d98c5)) non valida
/var/cache/urpmi/rpms/systemd-boot-238-2-omv2015.0.x86_64.rpm: Key ID (OK (RSA/SHA1, sab 24 mar 2018 01:48:09 CET, Key ID 64aca0ca954d98c5)) non valida
/var/cache/urpmi/rpms/systemd-console-238-2-omv2015.0.x86_64.rpm: Key ID (OK (RSA/SHA1, sab 24 mar 2018 01:48:10 CET, Key ID 64aca0ca954d98c5)) non valida
/var/cache/urpmi/rpms/systemd-coredump-238-2-omv2015.0.x86_64.rpm: Key ID (OK (RSA/SHA1, sab 24 mar 2018 01:48:10 CET, Key ID 64aca0ca954d98c5)) non valida
/var/cache/urpmi/rpms/systemd-documentation-238-2-omv2015.0.x86_64.rpm: Key ID (OK (RSA/SHA1, sab 24 mar 2018 01:48:10 CET, Key ID 64aca0ca954d98c5)) non valida
/var/cache/urpmi/rpms/systemd-hwdb-238-2-omv2015.0.x86_64.rpm: Key ID (OK (RSA/SHA1, sab 24 mar 2018 01:48:10 CET, Key ID 64aca0ca954d98c5)) non valida
/var/cache/urpmi/rpms/systemd-locale-238-2-omv2015.0.x86_64.rpm: Key ID (OK (RSA/SHA1, sab 24 mar 2018 01:48:13 CET, Key ID 64aca0ca954d98c5)) non valida
/var/cache/urpmi/rpms/systemd-polkit-238-2-omv2015.0.x86_64.rpm: Key ID (OK (RSA/SHA1, sab 24 mar 2018 01:48:13 CET, Key ID 64aca0ca954d98c5)) non valida
Vuoi proseguire con l'installazione? (s/N)
Just updated another system that had all the packages @rugyada shows so the list is indeed longer than I reported in my first post and includes all in @rugyada’s list.
FWIW that was a notebook that does not get updated as often as my desktop. Desktop get updated once or more per day.
