@Soulbound_Dagger don’t give up: someone is looking into it ![]()
@Soulbound_Dagger If you are still here, we have the package built for you.
sudo dnf install --enablerepo=cooker-x86_64-extra kup --refresh
Do I have to upgrade to Cooker?
I’ve tried running that command from Rolling and DNF does not like it one bit.
EDIT:
The new package doesn’t play nice with kde5, but that’s all good - I’ve swapped over to KDE6, anyway.
Thank you for your efforts kind OpenMandriva team!
No, that should only enable that one package to come from cooker.
Can you show the error it gave, I might have gotten a mistake in there.
Playing middle man here. ![]()
If worse comes to worse, it should be in the regular repos in a couple of days.
Looking to see if I did the command wrong.
I see the mistake. I had a X and needed x
Hit the charlimit, this will be split.
She’s a biggun. Good thing the drop-down hiding this is easy to find.
DNF Vomit
Error: Transaction test error:
file /usr/lib64/libexec/ksysguard/ksgrd_network_helper from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/dbus-1/system-services/org.kde.ksysguard.processlisthelper.service from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/dbus-1/system.d/org.kde.ksysguard.processlisthelper.conf from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/knsrcfiles/systemmonitor-faces.knsrc from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/knsrcfiles/systemmonitor-presets.knsrc from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/ksysguard/sensorfaces/org.kde.ksysguard.barchart/contents/config/main.xml from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/ksysguard/sensorfaces/org.kde.ksysguard.barchart/contents/ui/BarChart.qml from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/ksysguard/sensorfaces/org.kde.ksysguard.barchart/contents/ui/CompactRepresentation.qml from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/ksysguard/sensorfaces/org.kde.ksysguard.barchart/contents/ui/Config.qml from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/ksysguard/sensorfaces/org.kde.ksysguard.barchart/contents/ui/FullRepresentation.qml from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/ksysguard/sensorfaces/org.kde.ksysguard.barchart/metadata.json from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/ksysguard/sensorfaces/org.kde.ksysguard.colorgrid/contents/ui/CompactRepresentation.qml from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/ksysguard/sensorfaces/org.kde.ksysguard.colorgrid/contents/ui/Config.qml from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/ksysguard/sensorfaces/org.kde.ksysguard.colorgrid/contents/ui/FaceGrid.qml from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/ksysguard/sensorfaces/org.kde.ksysguard.colorgrid/contents/ui/FullRepresentation.qml from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/ksysguard/sensorfaces/org.kde.ksysguard.colorgrid/contents/ui/SensorRect.qml from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/ksysguard/sensorfaces/org.kde.ksysguard.colorgrid/metadata.json from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/ksysguard/sensorfaces/org.kde.ksysguard.facegrid/contents/ui/CompactRepresentation.qml from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/ksysguard/sensorfaces/org.kde.ksysguard.facegrid/contents/ui/Config.qml from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/ksysguard/sensorfaces/org.kde.ksysguard.facegrid/contents/ui/FaceControl.qml from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/ksysguard/sensorfaces/org.kde.ksysguard.facegrid/contents/ui/FaceGrid.qml from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/ksysguard/sensorfaces/org.kde.ksysguard.facegrid/contents/ui/FullRepresentation.qml from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/ksysguard/sensorfaces/org.kde.ksysguard.facegrid/metadata.json from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/ksysguard/sensorfaces/org.kde.ksysguard.horizontalbars/contents/ui/Bar.qml from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/ksysguard/sensorfaces/org.kde.ksysguard.horizontalbars/contents/ui/CompactRepresentation.qml from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/ksysguard/sensorfaces/org.kde.ksysguard.horizontalbars/contents/ui/FullRepresentation.qml from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/ksysguard/sensorfaces/org.kde.ksysguard.horizontalbars/metadata.json from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/ksysguard/sensorfaces/org.kde.ksysguard.linechart/contents/ui/CompactRepresentation.qml from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/ksysguard/sensorfaces/org.kde.ksysguard.linechart/contents/ui/Config.qml from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/ksysguard/sensorfaces/org.kde.ksysguard.linechart/contents/ui/FullRepresentation.qml from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/ksysguard/sensorfaces/org.kde.ksysguard.linechart/contents/ui/LineChart.qml from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/ksysguard/sensorfaces/org.kde.ksysguard.linechart/metadata.json from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/ksysguard/sensorfaces/org.kde.ksysguard.piechart/contents/ui/CompactRepresentation.qml from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/ksysguard/sensorfaces/org.kde.ksysguard.piechart/contents/ui/Config.qml from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/ksysguard/sensorfaces/org.kde.ksysguard.piechart/contents/ui/FullRepresentation.qml from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/ksysguard/sensorfaces/org.kde.ksysguard.piechart/contents/ui/PieChart.qml from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/ksysguard/sensorfaces/org.kde.ksysguard.piechart/contents/ui/UsedTotalDisplay.qml from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/ksysguard/sensorfaces/org.kde.ksysguard.piechart/metadata.json from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/ksysguard/sensorfaces/org.kde.ksysguard.textonly/contents/ui/CompactRepresentation.qml from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/ksysguard/sensorfaces/org.kde.ksysguard.textonly/contents/ui/Config.qml from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/ksysguard/sensorfaces/org.kde.ksysguard.textonly/contents/ui/FullRepresentation.qml from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/ksysguard/sensorfaces/org.kde.ksysguard.textonly/contents/ui/GroupedText.qml from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/ksysguard/sensorfaces/org.kde.ksysguard.textonly/metadata.json from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ar/LC_MESSAGES/KSysGuardFormatter.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ar/LC_MESSAGES/KSysGuardSensorFaces.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ar/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.barchart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ar/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.colorgrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ar/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.facegrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ar/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.linechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ar/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.piechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ar/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.textonly.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ar/LC_MESSAGES/processcore.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/az/LC_MESSAGES/KSysGuardSensorFaces.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/az/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.barchart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/az/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.colorgrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/az/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.facegrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/az/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.linechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/az/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.piechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/az/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.textonly.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/az/LC_MESSAGES/processcore.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/bg/LC_MESSAGES/KSysGuardFormatter.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/bg/LC_MESSAGES/KSysGuardSensorFaces.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/bg/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.barchart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/bg/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.colorgrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/bg/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.facegrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/bg/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.linechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/bg/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.piechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/bg/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.textonly.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/bg/LC_MESSAGES/ksysguard_systemstats.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/bg/LC_MESSAGES/processcore.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ca/LC_MESSAGES/KSysGuardFormatter.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ca/LC_MESSAGES/KSysGuardSensorFaces.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ca/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.barchart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ca/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.colorgrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ca/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.facegrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ca/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.linechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ca/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.piechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ca/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.textonly.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ca/LC_MESSAGES/ksysguard_sensors.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ca/LC_MESSAGES/processcore.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ca@valencia/LC_MESSAGES/KSysGuardFormatter.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ca@valencia/LC_MESSAGES/KSysGuardSensorFaces.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ca@valencia/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.barchart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ca@valencia/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.colorgrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ca@valencia/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.facegrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ca@valencia/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.linechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ca@valencia/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.piechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ca@valencia/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.textonly.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ca@valencia/LC_MESSAGES/ksysguard_sensors.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ca@valencia/LC_MESSAGES/processcore.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/cs/LC_MESSAGES/KSysGuardFormatter.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/cs/LC_MESSAGES/KSysGuardSensorFaces.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/cs/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.barchart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/cs/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.colorgrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/cs/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.facegrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/cs/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.linechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/cs/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.piechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/cs/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.textonly.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/cs/LC_MESSAGES/processcore.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/da/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.barchart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/da/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.linechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/da/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.piechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/de/LC_MESSAGES/KSysGuardFormatter.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/de/LC_MESSAGES/KSysGuardSensorFaces.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/de/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.barchart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/de/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.colorgrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/de/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.facegrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/de/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.linechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/de/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.piechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/de/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.textonly.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/de/LC_MESSAGES/processcore.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/el/LC_MESSAGES/processcore.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/en_GB/LC_MESSAGES/KSysGuardFormatter.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/en_GB/LC_MESSAGES/KSysGuardSensorFaces.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/en_GB/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.barchart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/en_GB/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.colorgrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/en_GB/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.facegrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/en_GB/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.linechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/en_GB/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.piechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/en_GB/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.textonly.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/en_GB/LC_MESSAGES/ksysguard_systemstats.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/en_GB/LC_MESSAGES/processcore.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/eo/LC_MESSAGES/KSysGuardFormatter.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/eo/LC_MESSAGES/KSysGuardSensorFaces.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/eo/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.barchart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/eo/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.colorgrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/eo/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.facegrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/eo/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.linechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/eo/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.piechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/eo/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.textonly.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/eo/LC_MESSAGES/ksysguard_sensors.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/eo/LC_MESSAGES/processcore.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/es/LC_MESSAGES/KSysGuardFormatter.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/es/LC_MESSAGES/KSysGuardSensorFaces.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/es/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.barchart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/es/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.colorgrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/es/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.facegrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/es/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.linechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/es/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.piechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/es/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.textonly.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/es/LC_MESSAGES/ksysguard_systemstats.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/es/LC_MESSAGES/processcore.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/et/LC_MESSAGES/KSysGuardSensorFaces.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/et/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.barchart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/et/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.linechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/et/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.piechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/et/LC_MESSAGES/processcore.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/eu/LC_MESSAGES/KSysGuardFormatter.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/eu/LC_MESSAGES/KSysGuardSensorFaces.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/eu/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.barchart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/eu/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.colorgrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/eu/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.facegrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/eu/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.linechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/eu/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.piechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/eu/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.textonly.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/eu/LC_MESSAGES/ksysguard_systemstats.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
2
file /usr/share/locale/eu/LC_MESSAGES/processcore.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/fi/LC_MESSAGES/KSysGuardFormatter.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/fi/LC_MESSAGES/KSysGuardSensorFaces.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/fi/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.barchart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/fi/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.colorgrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/fi/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.facegrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/fi/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.linechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/fi/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.piechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/fi/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.textonly.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/fi/LC_MESSAGES/processcore.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/fr/LC_MESSAGES/KSysGuardFormatter.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/fr/LC_MESSAGES/KSysGuardSensorFaces.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/fr/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.barchart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/fr/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.colorgrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/fr/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.facegrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/fr/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.linechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/fr/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.piechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/fr/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.textonly.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/fr/LC_MESSAGES/ksysguard_sensors.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/fr/LC_MESSAGES/processcore.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/gl/LC_MESSAGES/KSysGuardFormatter.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/gl/LC_MESSAGES/KSysGuardSensorFaces.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/gl/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.barchart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/gl/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.colorgrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/gl/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.facegrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/gl/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.linechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/gl/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.piechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/gl/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.textonly.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/gl/LC_MESSAGES/processcore.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/he/LC_MESSAGES/processcore.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/hu/LC_MESSAGES/KSysGuardSensorFaces.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/hu/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.barchart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/hu/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.facegrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/hu/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.linechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/hu/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.piechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/hu/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.textonly.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/hu/LC_MESSAGES/processcore.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ia/LC_MESSAGES/KSysGuardFormatter.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ia/LC_MESSAGES/KSysGuardSensorFaces.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ia/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.barchart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ia/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.colorgrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ia/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.facegrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ia/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.linechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ia/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.piechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ia/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.textonly.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ia/LC_MESSAGES/ksysguard_sensors.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ia/LC_MESSAGES/ksysguard_systemstats.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ia/LC_MESSAGES/processcore.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/it/LC_MESSAGES/KSysGuardFormatter.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/it/LC_MESSAGES/KSysGuardSensorFaces.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/it/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.barchart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/it/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.colorgrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/it/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.facegrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/it/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.linechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/it/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.piechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/it/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.textonly.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/it/LC_MESSAGES/ksysguard_sensors.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/it/LC_MESSAGES/processcore.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ja/LC_MESSAGES/KSysGuardSensorFaces.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ja/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.piechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ja/LC_MESSAGES/processcore.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ka/LC_MESSAGES/KSysGuardFormatter.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ka/LC_MESSAGES/KSysGuardSensorFaces.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ka/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.barchart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ka/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.colorgrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ka/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.facegrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ka/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.linechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ka/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.piechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ka/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.textonly.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ka/LC_MESSAGES/processcore.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ko/LC_MESSAGES/KSysGuardFormatter.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ko/LC_MESSAGES/KSysGuardSensorFaces.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ko/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.barchart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ko/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.colorgrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ko/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.facegrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ko/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.linechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ko/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.piechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ko/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.textonly.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ko/LC_MESSAGES/processcore.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/lt/LC_MESSAGES/KSysGuardSensorFaces.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/lt/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.barchart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/lt/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.linechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/lt/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.piechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/lt/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.textonly.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/lt/LC_MESSAGES/processcore.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/nl/LC_MESSAGES/KSysGuardFormatter.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/nl/LC_MESSAGES/KSysGuardSensorFaces.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/nl/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.barchart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/nl/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.colorgrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/nl/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.facegrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/nl/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.linechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/nl/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.piechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/nl/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.textonly.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/nl/LC_MESSAGES/ksysguard_systemstats.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/nl/LC_MESSAGES/processcore.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/nn/LC_MESSAGES/KSysGuardFormatter.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/nn/LC_MESSAGES/KSysGuardSensorFaces.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/nn/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.barchart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/nn/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.colorgrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/nn/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.facegrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/nn/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.linechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/nn/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.piechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/nn/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.textonly.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/nn/LC_MESSAGES/processcore.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/pa/LC_MESSAGES/processcore.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/pl/LC_MESSAGES/KSysGuardFormatter.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/pl/LC_MESSAGES/KSysGuardSensorFaces.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/pl/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.barchart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/pl/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.colorgrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/pl/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.facegrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/pl/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.linechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/pl/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.piechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/pl/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.textonly.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/pl/LC_MESSAGES/ksysguard_systemstats.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/pl/LC_MESSAGES/processcore.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/pt/LC_MESSAGES/KSysGuardSensorFaces.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/pt/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.barchart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/pt/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.colorgrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/pt/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.facegrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/pt/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.linechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/pt/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.piechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/pt/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.textonly.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/pt/LC_MESSAGES/processcore.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/pt_BR/LC_MESSAGES/KSysGuardSensorFaces.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/pt_BR/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.barchart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/pt_BR/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.facegrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/pt_BR/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.linechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/pt_BR/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.piechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/pt_BR/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.textonly.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/pt_BR/LC_MESSAGES/processcore.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ro/LC_MESSAGES/KSysGuardSensorFaces.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ro/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.barchart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ro/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.facegrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ro/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.linechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ro/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.piechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ro/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.textonly.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ro/LC_MESSAGES/processcore.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ru/LC_MESSAGES/KSysGuardFormatter.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ru/LC_MESSAGES/KSysGuardSensorFaces.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ru/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.barchart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ru/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.colorgrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ru/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.facegrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ru/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.linechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ru/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.piechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ru/LC_MESSAGES/processcore.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/sk/LC_MESSAGES/KSysGuardFormatter.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/sk/LC_MESSAGES/KSysGuardSensorFaces.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/sk/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.barchart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/sk/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.colorgrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/sk/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.facegrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/sk/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.linechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/sk/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.piechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/sk/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.textonly.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/sk/LC_MESSAGES/ksysguard_sensors.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/sk/LC_MESSAGES/ksysguard_systemstats.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/sk/LC_MESSAGES/processcore.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/sl/LC_MESSAGES/KSysGuardFormatter.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/sl/LC_MESSAGES/KSysGuardSensorFaces.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/sl/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.barchart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/sl/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.colorgrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with
3
file /usr/share/locale/sl/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.facegrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/sl/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.linechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/sl/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.piechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/sl/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.textonly.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/sl/LC_MESSAGES/processcore.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/sv/LC_MESSAGES/KSysGuardFormatter.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/sv/LC_MESSAGES/KSysGuardSensorFaces.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/sv/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.barchart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/sv/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.colorgrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/sv/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.facegrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/sv/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.linechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/sv/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.piechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/sv/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.textonly.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/sv/LC_MESSAGES/ksysguard_systemstats.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/sv/LC_MESSAGES/processcore.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ta/LC_MESSAGES/processcore.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/tr/LC_MESSAGES/KSysGuardSensorFaces.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/tr/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.barchart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/tr/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.colorgrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/tr/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.facegrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/tr/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.linechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/tr/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.piechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/tr/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.textonly.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/tr/LC_MESSAGES/processcore.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/uk/LC_MESSAGES/KSysGuardFormatter.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/uk/LC_MESSAGES/KSysGuardSensorFaces.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/uk/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.barchart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/uk/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.colorgrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/uk/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.facegrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/uk/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.linechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/uk/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.piechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/uk/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.textonly.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/uk/LC_MESSAGES/processcore.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/vi/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.barchart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/vi/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.colorgrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/vi/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.facegrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/vi/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.linechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/vi/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.piechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/vi/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.textonly.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/zh_CN/LC_MESSAGES/KSysGuardFormatter.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/zh_CN/LC_MESSAGES/KSysGuardSensorFaces.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/zh_CN/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.barchart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/zh_CN/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.colorgrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/zh_CN/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.facegrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/zh_CN/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.linechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/zh_CN/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.piechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/zh_CN/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.textonly.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/zh_CN/LC_MESSAGES/ksysguard_sensors.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/zh_CN/LC_MESSAGES/ksysguard_systemstats.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/zh_CN/LC_MESSAGES/processcore.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/zh_TW/LC_MESSAGES/KSysGuardSensorFaces.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/zh_TW/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.barchart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/zh_TW/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.facegrid.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/zh_TW/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.linechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/zh_TW/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.piechart.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/zh_TW/LC_MESSAGES/ksysguard_face_org.kde.ksysguard.textonly.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/zh_TW/LC_MESSAGES/ksysguard_sensors.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/zh_TW/LC_MESSAGES/processcore.mo from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/polkit-1/actions/org.kde.ksysguard.processlisthelper.policy from install of plasma6-libksysguard-6.3.4-1.x86_64 conflicts with file from package libksysguard-5.27.12-1.x86_64
file /usr/share/locale/ar/LC_MESSAGES/plasma_engine_soliddevice.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/az/LC_MESSAGES/plasma_engine_soliddevice.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/be/LC_MESSAGES/plasma_engine_devicenotifications.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/be/LC_MESSAGES/plasma_engine_hotplug.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/be/LC_MESSAGES/plasma_engine_keystate.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/be/LC_MESSAGES/plasma_engine_powermanagement.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/be/LC_MESSAGES/plasma_engine_soliddevice.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/bg/LC_MESSAGES/plasma_engine_devicenotifications.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/bg/LC_MESSAGES/plasma_engine_soliddevice.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/ca/LC_MESSAGES/plasma_engine_devicenotifications.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/ca/LC_MESSAGES/plasma_engine_hotplug.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/ca/LC_MESSAGES/plasma_engine_keystate.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/ca/LC_MESSAGES/plasma_engine_powermanagement.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/ca/LC_MESSAGES/plasma_engine_soliddevice.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/ca@valencia/LC_MESSAGES/plasma_engine_devicenotifications.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/ca@valencia/LC_MESSAGES/plasma_engine_hotplug.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/ca@valencia/LC_MESSAGES/plasma_engine_keystate.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/ca@valencia/LC_MESSAGES/plasma_engine_powermanagement.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/ca@valencia/LC_MESSAGES/plasma_engine_soliddevice.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/cs/LC_MESSAGES/plasma_engine_devicenotifications.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/cs/LC_MESSAGES/plasma_engine_soliddevice.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/da/LC_MESSAGES/plasma_engine_soliddevice.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/de/LC_MESSAGES/plasma_engine_soliddevice.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/el/LC_MESSAGES/plasma_engine_keystate.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/el/LC_MESSAGES/plasma_engine_soliddevice.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/en_GB/LC_MESSAGES/plasma_engine_devicenotifications.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/en_GB/LC_MESSAGES/plasma_engine_soliddevice.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/eo/LC_MESSAGES/plasma_engine_devicenotifications.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/eo/LC_MESSAGES/plasma_engine_hotplug.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/eo/LC_MESSAGES/plasma_engine_powermanagement.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/eo/LC_MESSAGES/plasma_engine_soliddevice.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/es/LC_MESSAGES/plasma_engine_devicenotifications.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/es/LC_MESSAGES/plasma_engine_soliddevice.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/et/LC_MESSAGES/plasma_engine_soliddevice.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/eu/LC_MESSAGES/plasma_engine_devicenotifications.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/eu/LC_MESSAGES/plasma_engine_soliddevice.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/fi/LC_MESSAGES/plasma_engine_soliddevice.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/fr/LC_MESSAGES/plasma_engine_devicenotifications.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/fr/LC_MESSAGES/plasma_engine_soliddevice.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/gl/LC_MESSAGES/plasma_engine_soliddevice.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/he/LC_MESSAGES/plasma_engine_devicenotifications.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/he/LC_MESSAGES/plasma_engine_keystate.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/he/LC_MESSAGES/plasma_engine_powermanagement.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/he/LC_MESSAGES/plasma_engine_soliddevice.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/hi/LC_MESSAGES/plasma_engine_devicenotifications.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/hi/LC_MESSAGES/plasma_engine_soliddevice.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/hu/LC_MESSAGES/plasma_engine_devicenotifications.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/hu/LC_MESSAGES/plasma_engine_soliddevice.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/ia/LC_MESSAGES/plasma_engine_devicenotifications.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/ia/LC_MESSAGES/plasma_engine_soliddevice.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/id/LC_MESSAGES/plasma_engine_soliddevice.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/is/LC_MESSAGES/plasma_engine_devicenotifications.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/is/LC_MESSAGES/plasma_engine_soliddevice.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/it/LC_MESSAGES/plasma_engine_devicenotifications.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/it/LC_MESSAGES/plasma_engine_soliddevice.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/ja/LC_MESSAGES/plasma_engine_soliddevice.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/ka/LC_MESSAGES/plasma_engine_devicenotifications.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/ka/LC_MESSAGES/plasma_engine_soliddevice.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/ko/LC_MESSAGES/plasma_engine_soliddevice.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/lt/LC_MESSAGES/plasma_engine_devicenotifications.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/lt/LC_MESSAGES/plasma_engine_soliddevice.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/lv/LC_MESSAGES/plasma_engine_soliddevice.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/ml/LC_MESSAGES/plasma_engine_soliddevice.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/nl/LC_MESSAGES/plasma_engine_devicenotifications.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/nl/LC_MESSAGES/plasma_engine_soliddevice.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/nn/LC_MESSAGES/plasma_engine_soliddevice.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/pa/LC_MESSAGES/plasma_engine_soliddevice.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/pl/LC_MESSAGES/plasma_engine_soliddevice.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/pt/LC_MESSAGES/plasma_engine_soliddevice.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/pt_BR/LC_MESSAGES/plasma_engine_devicenotifications.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/pt_BR/LC_MESSAGES/plasma_engine_soliddevice.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/ro/LC_MESSAGES/plasma_engine_soliddevice.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/ru/LC_MESSAGES/plasma_engine_devicenotifications.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/ru/LC_MESSAGES/plasma_engine_soliddevice.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/sk/LC_MESSAGES/plasma_engine_devicenotifications.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/sk/LC_MESSAGES/plasma_engine_soliddevice.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/sl/LC_MESSAGES/plasma_engine_devicenotifications.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/sl/LC_MESSAGES/plasma_engine_soliddevice.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/sv/LC_MESSAGES/plasma_engine_devicenotifications.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/sv/LC_MESSAGES/plasma_engine_soliddevice.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/ta/LC_MESSAGES/plasma_engine_devicenotifications.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/ta/LC_MESSAGES/plasma_engine_soliddevice.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/tok/LC_MESSAGES/plasma_engine_hotplug.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/tr/LC_MESSAGES/plasma_engine_devicenotifications.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/tr/LC_MESSAGES/plasma_engine_soliddevice.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/uk/LC_MESSAGES/plasma_engine_devicenotifications.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/uk/LC_MESSAGES/plasma_engine_soliddevice.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/vi/LC_MESSAGES/plasma_engine_soliddevice.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/zh_CN/LC_MESSAGES/plasma_engine_devicenotifications.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/zh_CN/LC_MESSAGES/plasma_engine_hotplug.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/zh_CN/LC_MESSAGES/plasma_engine_keystate.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/zh_CN/LC_MESSAGES/plasma_engine_powermanagement.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/zh_CN/LC_MESSAGES/plasma_engine_soliddevice.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/zh_TW/LC_MESSAGES/plasma_engine_devicenotifications.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
file /usr/share/locale/zh_TW/LC_MESSAGES/plasma_engine_soliddevice.mo from install of kf6-plasma5support-6.3.4-1.x86_64 conflicts with file from package plasma-workspace-5.27.12-3.x86_64
Edit: Hit the max new posts for my account today. If you need anything else I’ll try to remember to reply tommorrow.
Edit2: It depends on Plasma6 - I’ll reinstall via a wayland plasma6 cooker iso and see if that lets me install without issue.
Use the last one I gave It was case sensitive and it screwed it up
@Soulbound_Dagger I tried installing kup to test it. I cannot get it to run. KDE no longer supports it as they have moved on to kbackup which does not run on rsync. However, I do run grsync for my backups and it does work well. I know it is a GTK app and I hate the GTK file picker, but it does get the job done for me. I don’t know if you have tried it.
It did not create a .desktop file, so there is no icon in the kickoff menu. I run it from the command line but no luck.
┌──[wilson@heisenberg] Wed Apr 09, 10:00:43 [~]
└──[ <$> kup
bash: kup: command not found
┌──[wilson@heisenberg] Wed Apr 09, 10:00:46 [~]
└──[ <$> dnf info kup
OpenMandriva Rolling - znver1 3.5 MB/s | 5.3 MB 00:01
OpenMandriva Rolling - Extra - znver1 1.3 MB/s | 1.4 MB 00:01
OpenMandriva Rolling - Restricted - znver1 44 kB/s | 36 kB 00:00
OpenMandriva Rolling - Non-free - znver1 37 kB/s | 30 kB 00:00
Installed Packages
Version : 0.10.0
Release : 2
Architecture : znver1
Source : kup-0.10.0-2.src.rpm
Repository : @System
From repo : cooker-znver1-extra
Summary : A KDE-based frontend for the very excellent backup software
URL : https://invent.kde.org/system/kup
License : GPLv2+
Description : Kup is created for helping people to keep up-to-date backups of their personal
: files.
: Backup types:
: - Synchronized folders with the use of "rsync".
: - Incremental backup archive with the use of "bup"
: Backup destinations:
: - local filesystem, monitored for availability. That means you can set
: a destination folder which only exist when perhaps a network shared drive
: is mounted and Kup will detect when it becomes available.
: - external storage, like usb hard drives. Also monitored for availability.
: Schedules:
: - manual only (triggered from tray icon popup menu)
: - interval (suggests new backup after some time has passed since last backup)
: - usage based (suggests new backup after you have been active on your computer
: for some hours since last backup).
Configure is in systemsettings > Backups
Start is in Add widgets > Backup Status
I still did not manage to backup the dot files in ~/.config ![]()
Postedit
Correction: got it now ![]()
Thank you @rugyada. I had no idea it opened from there. It seems to be working on mine, but I need to run it and see if I can get a backup with it. This looks way better than kbackup. I mean there is no comparison.
@Soulbound_Dagger, can you please give it a test when possible? I installed it with this.
sudo dnf install --enablerepo=cooker-x86_64-extra kup --refresh
It seems a nice little app actually.
Versioned Backup (not available because bup is not installed)
It can’t read incremental backups because of this either.
I’ve copied my main backup onto a portable SSD for testing. I use the ‘advanced’ options
because I’m paranoid, but if this works it should be good for most incremental backups.
I’m manually installing ‘bup’, and the built-in tester says test (test-gc-removes-incomplete-trees) is failing, though I’m not sure if that’s a problem. I make installed anyway and it versioned backups are now available.
But I still can’t read my backups because “Generate recovery information (not available because par2 is not installed)”
l’ll try compiling par2 tomorrow.
Anyway, the steps to get incremental backups at this point in time:
Installed the following packages from the repo: “task-devel python-devel git python-pytest”
(Don’t know if all of those are required)
Download bup release from github,
unzip and get into the bup-##.# folder,
then make config → make long-check (wait for check to complete) → make install (no modifiers)
then, kup can see bup.
Hello, I have updated bup and all of its requirements today in cooker, the changes required to kup are in the pipeline.
If you are looking for par2 / par2cmdline it is in the parchive2 package, which I have also updated today in cooker.
They will make their way down to ROME/Rolling soon.
If you don’t want to wait.
sudo dnf install --enablerepo=cooker-x86_64-extra bup --refresh
That also upgraded the parchive2 package for me.
My backups are accessible.
Panicked for a bit when I couldn’t open them but there was just some permission issues from how I rsync-ed it over to the portable drive. Thank you very much.
EDIT:
Jumped the gun, “xattr.set FILENAME: [Errno1] Operation not permitted”
Seems to be a non-issue, a labeling thing for users? Everything else seems to have been restored fine.
