Checking to see if anyone notices this before filing a bug report. One of the things is that when I select om-welcome from the Application Launcher it does not open. If I run it from Konsole I get a plasmashell dialog box that indicates segfault. In KDE Menu Editor the path (/usr/bin/om-welcome) appears to be correct.
$ coredumpctl dump om-welcome
PID: 6273 (om-welcome)
UID: 1001 (ben79)
GID: 1006 (ben79)
Signal: 11 (SEGV)
Timestamp: Sun 2016-11-27 12:52:48 CST (5min ago)
Command Line: /usr/bin/om-welcome --tempfile
Executable: /usr/bin/om-welcome
Control Group: /user.slice/user-1001.slice/session-1.scope
Unit: session-1.scope
Slice: user-1001.slice
Session: 1
Owner UID: 1001 (ben79)
Boot ID: f6c6cf5b48024467a1c4cd5ffd929d30
Machine ID: 191ceaa06531f04591e4165f57ad0159
Hostname: ben-pc
Storage: /var/lib/systemd/coredump/core.om-welcome.1001.f6c6cf5b48024467a1c4cd5ffd929d30.6273.1480272768000000000000.lz4
Message: Process 6273 (om-welcome) of user 1001 dumped core.
Refusing to dump core to tty (use shell redirection or specify --output).
