Hi Ben.
I donāt use āauto loginā. And I also have a nVidia graphic card. In my system, after āUser=ā in [Autologin] says āliveā (without quotes)
I cannot boot in graphic mode in any way. I tried to disable the nvidia driver (now using nouveau), and I also already tried ānokmsbootā and ānokmsmodeā editing grub menu at boot time. Configuring with drakconf and using MCC, I disabled the āboot in graphic modeā option.
The system boots up (OpenMandriva 3.01, 64-bits), but screen remains black, with no text cursor nor mouse arrow. The only workaround I found by chance is to change to another terminal, using Ctrl+Alt+F2, login as root, kill (using kill -9) the Xorg process, and only then, coming back to Ctrl+Alt+F1, I get the login option.
After that, the graphic mode starts (Iām writing from 3.01 in this moment), but now and then screen goes totally black. To recover the graphic screen I must change to Ctrl+Alt+F2 and/or Ctrl+Alt+F3 and then back to Ctrl+Alt+F1 and wait for a few seconds.
Itās really annoying.
As my system includes an integrated Intel graphic card (supposedly disabled in BIOS), I donāt know if the origin of the problem can be there.
Now updating some things (but other updates just didnāt worked out !!). I hope that, with more time, I can give you more info.
# inxi -F
System: Host: Sirius2 Kernel: 4.9.0-desktop-1omv x86_64 (64 bit) Desktop: KDE Plasma 5.8.4
Distro: OpenMandrivaLinux 3.0 Einsteinium
Machine: System: Gigabyte product: N/A
Mobo: Gigabyte model: B75M-D3H v: x.x Bios: American Megatrends v: F14 date: 04/17/2013
CPU: Quad core Intel Core i5-3340 (-MCP-) cache: 6144 KB
clock speeds: max: 3300 MHz 1: 2736 MHz 2: 3029 MHz 3: 2893 MHz 4: 3231 MHz
Graphics: Card: NVIDIA GK107 [GeForce GTX 650]
Display Server: X.org 1.19.0 driver: nouveau tty size: 152x38 Advanced Data: N/A for root
Audio: Card-1 NVIDIA GK107 HDMI Audio Controller driver: snd_hda_intel Sound: ALSA v: k4.9.0-desktop-1omv
Card-2 Intel 7 Series/C216 Family High Definition Audio Controller driver: snd_hda_intel
Network: Card: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller driver: r8169
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: 74:d4:35:16:ce:06
Drives: HDD Total Size: 1000.2GB (89.2% used) ID-1: /dev/sda model: WDC_WD10EZEX size: 1000.2GB
Partition: ID-1: / size: 9.8G used: 6.3G (68%) fs: ext3 dev: /dev/sda7
ID-2: swap-1 size: 4.19GB used: 0.00GB (0%) fs: swap dev: /dev/sda4
RAID: No RAID devices: /proc/mdstat, md_mod kernel module present
Sensors: System Temperatures: cpu: 29.8C mobo: 27.8C gpu: 47.0
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 234 Uptime: 1:19 Memory: 1641.3/3899.2MB Client: Shell (bash) inxi: 2.2.27
I attach the bug report.
Greetings.
Sirius
omv-bug-report.log.xz (82,1 KB)
