Now reporting from OM LX 4.0 live mode.
Yesterday, some regular saving energy black screen started to take long for returning upon mouse or keyboard use.
Today, boot goes on but does not go to the sddm login screen. Instead of the login screen I got a black screen.
CTRL+ALT+F2 works and I was able to copy journalctl and Xorg.0.log to a pendrive. They are attached.journalctl.log2.txt (3,2 MB)
Xorg.0.log.txt (43,2 KB)
Thanks for reporting @adelson.oliveira. We appreciate users reporting issues.
Is it this?
Cooker boots to black after updates 2019-01-16
https://issues.openmandriva.org/show_bug.cgi?id=2413
May not be >>> for me CTRL+ALT+F2 did not work neither did âsystemctl restart sddmâ so yours may or may not be same issue. As you can see in bug report mine was fixed by âdnf --refresh updateâ. Hope yours is as easy to correct!
Ben,
Thanks, updating solved the problem.
If you had a black screen like me, how did you manage to get updates without CTRL+ALT+F#?
In my case, I couldnât update because network wasnât up. In the F2, I used nmtui-connect to make the connection and then finally do the update of the system.
And, another question, why discover didnât pointed to available updates yesterday and before?
Thanks again
What I thought you said was that you used CTRL+ALT+F# and got screen to work. Thatâs a common trick, first thing people try. Switch to a VT and then back to CTRL+ALT+F1 and sometimes you have a screen. Sometimes it works but sometimes not.
If you read the bug report I did say that I had virtual terminals (VTâs).
Did that change anything?
Discover is um, not popular for a reason, as I understand it OMA is going to remove Discover from default packages and replace it with dnfdragora. That is not an official statement. But I think that is what devs are going towards.
I boot to maintenance mode, enter the root password, then âinit 2â. Then I can login as root and run dnf --refresh upgrade (or anything else). The âinit 2â command starts the network (amongst other things).
My guess is @adelson.oliveira lost internet because of a wifi connection. If one has ethernet connection then internet worked form Virtual Terminal. With wifi then intervention was necessary and I donât know why that would be the case.
Is maintenance mode = recovery mode? Here, due to the hybrid graphics, recovery mode does not goes. For regular mode, Iâve blacklisted nouveau and I can boot.
Sorry for my poor english âŚ
No worries. Your English beats my Portuguese like a drum.
Apologies for getting sidetracked.
So anyway now I think you did have same issue I did and if so I hope updating corrected?
This issue is fixed.
Please update you system.
Yes, it is Ok now.
