No Login Screen
Hi,
I installed OM LX3 32bit. Linux Kernel 4.6.5.
System Worked fine.
I Update the package list
urpmi.update -a
After installing Semantik System Crash.
Need your Help.
Thanks,
Pujitha
Hard to help with so little information. Based on what you provided.
# urpme semantik
reboot.
Edit why 32 bit? Is it a 32 bit machine?
No,
http://www.foxconnchannel.com/ProductDetail.aspx?T=motherboard&U=en-us0000416
Motherboard G31MXP
Memory Dual channel DDR2 800/667/533 x 2 DIMMs, Max 4GB
the last bug report I filed 1991 – Login does not display. (Not this one)
Removed. rebooted, same.
So removed urpme --auto-orphans too.
no login.
So I set XFdark too. same.
Mr. Efrem knows lot of issues I had in the past.
