Hi, everyone
I moved to Linux as daily driver 2 months ago with Fedora KDE. I was able to run everything I needed so even though I still have a running Windows drive i don’t switch to it anymore. Since the hd where Fedora was installed starting having issues, I switched it with a new one and decided to test a non main-stream distro like Openmandriva 6 Rock. As a daily driver most of the things work as expected however compared to Fedora I encountered these issues:
Unable to install some packages like: nordvpn, portmaster
I even by looking at the posts on OM forum I still wasn’t able to make nordvpn install correctly. Had problems installing VeraCrypt too, but they have an .appimage version so was able to run that -
The Autostart GUI does not work. Its impossible to add apps on autostart, the change is undo when you change menu. There is a manual way to do it, but whats the point of making life harder.
Issue with Nextcloud account integration. Dolphin does not connect with it.
Unable to show the “Calendar Events” option in Digital Clock, because of errors installing kdepim-runtime kdepim-addons
The Wallet password kept being asked after reboot, also the admin pswd seems to get asked many more times compared to Fedora, even though I added myself on wheel and change the config to nopasswd line in sudoers, and remove the timeout for requesting it.
Anyway I still believe its a nice linux distro to use as daily driver. The Multimedia/Codecs stuff was easier then Fedora
