MATE desktop on OMLx 3.03
Users wishing to get MATE desktop on OMLx 3.03, they can do it thank to @mandian and his own personal repository.
Please enter the following commands in a root console
urpmi.addmedia --no-verify mandian_personal http://abf-downloads.openmandriva.org/mandian_personal/repository/3.0/x86_64/main/release
urpmi.update -a
urpmi task-mate openmandriva-mate-config
Please note that MATE desktop currently is not (yet :slight_smile: ) officially supported.
The present call is intended for testing purpose.
Any feedback will be highly appreciated.
Recent activity from @mandian. I believe I see new mate packages in contrib testing repo. Wondering if they are also being built for Cooker/Lx4?
Yes, I am refreshing MATE packages in parallel both in 3.0 (version 1.18, the same as in my personal repo) and Cooker (version 1.20). But I have’t finished yet.
Good job !
Good to know, currently task-mate in Lx 3 looks like it installs a mix of 1.14 and 1.18 packages.
task-mate.txt (9.0 KB)
It is because I updated all SPECs on github but I haven’t finished to build packages on ABF yet.
@TPG I got an issue with %rename macro in building packages on cooker. Maybe it is only an extra space, please could you take a look at this?
fixed
https://github.com/OpenMandrivaAssociation/caja/commit/034e95253a3d7a17ce16f4482c8cb0b22a01d258
@tpg it works , thanks. However the behaviour of %rename macro is not intuitive:
$ rpm --eval "%rename"
Obsoletes:	%{1} <
Provides:	%{1} =
It is like it takes only one argument:
$ rpm --eval "%rename foo"
Obsoletes:	foo <
Provides:	foo =
instead it can take two:
$ rpm --eval "%rename foo bar"
Obsoletes:	foo < bar
Provides:	foo = bar
so without the = it may work (not tested). :thinking:.
%rename macro just uses %{EVRD} from spec file.
For example
Epoch: 2
Version: 1
Release: 0.1
%rename bar
Above %rename will produce:
Obsoletes: bar < 2:1-0.1
Provides: bar = 2:1-0.1
MATE 1.18.x is in official repo now.
