Login Screen Display
Hi,
Hope you are safe with Corona virus.
  1. I created couple of user accounts using Kuser. And also deleted couple of accounts in OM Lx 4.1.
    log off then no login screen.
  2. Installed Brave Browser.
Fedora 28+, CentOS/RHEL 8+[¶]
(Installing Brave — Brave Browser documentation)
sudo dnf install dnf-plugins-core sudo dnf config-manager --add-repo https://brave-browser-rpm-release.s3.brave.com/x86_64/
sudo rpm --import https://brave-browser-rpm-release.s3.brave.com/brave-core.asc
sudo dnf install brave-browser
then done a dnf --refresh update
FYA,
Thanks,
Pujitha
Another thing. If I deleted the 1st user account created. Then other accounts created later ask root password for mount NTFS Partitions.
Thanks for the kind thought. Hope you and everyone where you are are safe as well.
I could not reproduce the problem with kuser. I created 2 new users and then removed 2 users and I still had a sddm login screen.
Maybe this is related: As I understand it: First user created is automatically added to the wheel group and thus gets certain permissions that subsequent users do not automatically get. For instance first user is automatically granted sudo rights. Of course you can add any user you wish to wheel group in KUser or any other group for that matter.
I done this
sudo chown dimuthu:dimuthu ~/.cache/*
sudo chown -R dimuthu:dimuthu ~/.cache/*
https://ubuntuforums.org/showthread.php?t=2185104
It worked but now not working. “Plasma Wayland” crashed. I tried to change to macos theme.
Plasma works fine.
