I installed SpiderOak app some time ago which was running fine up until a few days ago when it stopped. The following error appears at startup:
ImportError: /opt/SpiderOakONE/lib/libz.so.1: version `ZLIB_1.2.9' not found (required by /usr/lib64/libpng16.so.16)
The libz1 version currently installed is 1.2.11 while the app looks for 1.2.9. I believe the library was updated a few days ago and that is why the application stopped working. Is it possible to make it work with the updated library? Should I reinstall the app?
