LibreOffice mouse hover description box is solid black. Solved
Is this just my OM Lx 3.0 or does anyone else notice in LibreOffice the box that pops up with description when you hover mouse icon over one of the tool icons the box is solid black? Impossible to read.:confused:
Is LibreOffice a GTK2 or GTK3 app?
Hi Ben,
is systemsettings->color->options->apply colors to no-qt applications enabled?
try and disable it.
Thanks, Luca. Actually I found it disabled. So I enabled it and now the boxes are legible.
