Hello. I recently found out that Krita 5.0.2-4 in OpenMandriva 4.3 & Cooker crashes in certain conditions. For instance, switch to the layer/selection transform tool and try to resize the layer using any of the side nodes. Krita will immidiately crash with the following output to the console:
krita: symbol lookup error: /usr/lib64/libgsl.so.27: undefined symbol: cblas_dcopy
I suggest that some package maybe wasn’t included into the build dependencies list (was it lib64blas-devel?). Anyway, I’ll be very glad if the above problem will be fixed.
Also, I installed the SRPM of Krita and then tried to do the following on my local machine:
sudo dnf builddep krita
rpmbuild -ba $HOME/rpmbuild/SPECS/krita.spec
And I noticed that a lot of optional dependencies were not included:
-- The following OPTIONAL packages have not been found:
* WebP (required version >= 1.2.0), <https://developers.google.com/speed/webp>
Required by the WebP plugin
* KSeExpr (required version >= 4.0.0.0), <https://invent.kde.org/graphics/kseexpr>
Required by the SeExpr generator layer
* HEIF (required version >= 1.10.0), Library for loading and saving heif files., <https://github.com/strukturag/libheif>
Required by the Krita HEIF filter
* LibMyPaint, MyPaint brush engine API for C/C++
Required for the mypaint brush engine
It would be nice to max out Krita capabilities by including those optional packages.
