- OpenMandriva Lx version:
I tried Lx 4.3 and the last Rome snapshot (from July 17th I believe)
KDE
I have worked through Calamares and assigned a partition (FAT32) for EFI with the appropiate mountpoint and flag as well as two other partitions on a different harddrive for root and home. Calamares seems to nearly finish its installation but fails and reports an error about not being able to create a bootloader.
This should be the logfile of my installation
calamares-install.log.txt (89,8 KB)
And here is my inxi -F output
System: Host: omv-1262 Kernel: 5.17.1-desktop-2omv4050 x86_64 bits: 64 Desktop: KDE Plasma 5.23.5
Distro: OpenMandrivaLinux 4.3 Rome
Machine: Type: Desktop System: Gigabyte product: X570 AORUS ULTRA v: -CF serial: <superuser required>
Mobo: Gigabyte model: X570 AORUS ULTRA v: x.x serial: <superuser required>
UEFI: American Megatrends LLC. v: F34 date: 07/08/2021
CPU: Info: 8-Core model: AMD Ryzen 7 3700X bits: 64 type: MT MCP cache: L2: 4 MiB
Speed: 1995 MHz min/max: 2200/3600 MHz Core speeds (MHz): 1: 1995 2: 1964 3: 2131 4: 2723
5: 2195 6: 2194 7: 2196 8: 2058 9: 2197 10: 2193 11: 2052 12: 2124 13: 2195 14: 2194 15: 2194
16: 2196
Graphics: Device-1: AMD Navi 22 [Radeon RX 6700/6700 XT / 6800M] driver: amdgpu v: kernel
Display: x11 server: OpenMandriva X.org 1.21.1.3 driver: loaded: amdgpu,ati
unloaded: fbdev,modesetting,radeon,vesa resolution: 2560x1440~144Hz
OpenGL:
renderer: AMD Radeon RX 6700 XT (NAVY_FLOUNDER DRM 3.44.0 5.17.1-desktop-2omv4050 LLVM 13.0.0)
v: 4.6 Mesa 21.3.7
Audio: Device-1: AMD Navi 21 HDMI Audio [Radeon RX 6800/6800 XT / 6900 XT] driver: snd_hda_intel
Device-2: AMD Starship/Matisse HD Audio driver: snd_hda_intel
Sound Server-1: ALSA v: k5.17.1-desktop-2omv4050 running: yes
Sound Server-2: PipeWire v: 0.3.51 running: yes
Network: Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi
IF: wlp6s0 state: down mac: 1e:87:a1:6f:00:b2
Device-2: Intel I211 Gigabit Network driver: igb
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: b4:2e:99:a2:05:bc
Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb
Report: hciconfig ID: hci0 state: up address: 50:E0:85:BD:B8:29 bt-v: 3.0
Drives: Local Storage: total: 3.01 TiB used: 5.3 MiB (0.0%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO Plus 1TB size: 931.51 GiB
ID-2: /dev/nvme1n1 vendor: Samsung model: SSD 970 EVO Plus 500GB size: 465.76 GiB
ID-3: /dev/nvme2n1 vendor: Samsung model: SSD 970 EVO Plus 500GB size: 465.76 GiB
ID-4: /dev/sda vendor: Crucial model: CT250MX500SSD1 size: 232.89 GiB
ID-5: /dev/sdb vendor: Crucial model: CT1000MX500SSD1 size: 931.51 GiB
ID-6: /dev/sdc type: USB vendor: SanDisk model: Extreme size: 59.63 GiB
Swap: ID-1: swap-1 type: zram size: 8 GiB used: 0 KiB (0.0%) dev: /dev/zram0
Sensors: System Temperatures: cpu: 16.8 C mobo: N/A gpu: amdgpu temp: 36.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Info: Processes: 320 Uptime: 19m Memory: 31.36 GiB used: 8.88 GiB (28.3%) Shell: Bash inxi: 3.3.06
Please tell me if I can provide more useful information and thank you in advance for any help
