2022-05-10T22:00:00Z
The different versions of OMLx are explained further here.
Rolling is not yet “officially” announced. But it has been in use for well over a year and has proven to be as stable as Rock according to users and contributors. There is a goal to announce Rolling soon. Given all contributors are unpaid, part-time, volunteers sometimes our best intentions are delayed due to work, family, health, and other life considerations.
Most in the OM contributor group believe most users will prefer Rolling due to software packages being kept more up to date.
This “How to” is based on a very basic, default installation of Rock. Rock and OMLx 4.3 are the same thing right now. Also it is based on using only main repository and no extra or third party repos. It is recommended to disable any extra or third party repos for this procedure and re-enable them after you are done.
Important Note: Do not mix repos from different versions (update channels) of OMLx. Either use Rock or use Rolling. Do not mix them. You will have problems if you mix repositories.
Users that have done a lot of customizing to their system and/or who have installed a lot of additional software may encounter issues not uncovered by this type of test. Frankly there is no way to anticipate all scenarios of what a user might do.
Knowledge level required: Linux user comfortable with using terminal and basic Linux/Unix commands. You don’t need to be a system administrator or developer to do this.
How I did this test:
Install the Rock x86_64 ISO (#598) in VirtualBox. A command to verify what version of OMLx is installed is
cat /etc/release
. So we start with this:$ cat /etc/release
OpenMandriva Lx release 4.3 (Dysprosium) Official for x86_64
To check what repositories are enabled we use
dnf repolist
. Right now we should have:$ dnf repolist repo id repo name rock-updates-x86_64 OpenMandriva Rock - x86_64 - Updates rock-x86_64 OpenMandriva Rock - x86_64`
Then I open Konsole and upgrade system with:
$ sudo dnf clean all ; sudo dnf up
There was a new kernel installed so I reboot for the new kernel.
Open Software Repository Selector aka:
om-repo-picker
and select to change Update channel from Rock to Rolling.
That pops a window that tells user:
Instead of
dnf --refresh distro-sync
I prefer users to usednf clean all ; dnf distro-sync
. distro-sync can be abbreviated asdsync
. This is more important on systems that have been in use for a while. --refesh option forces dnf to update repos to latest metadata.dnf clean all
does that and removes any old .rpm files from cache. This can be important on older systems.Now
dnf repolist
should show:$ dnf repolist repo id repo name rolling-x86_64 OpenMandriva Rolling - x86_64
Notice that no third party or additional repos are enabled at present. I recommend to disable them for this procedure and re-enable them after.
Now for the actual procedure:
$ sudo dnf clean all ; sudo dnf dsync
Reboot into your new Rolling system with a new
kernel-release-desktop-5.17.1-2
. Nowcat /etc/release
should show:
$ cat /etc/release
OpenMandriva Lx release 4.50 (Rome) Rolling for x86_64
Recommended method to update Rolling systems is to open Konsole(terminal) and:
Now your job as a happy user is to enjoy your new Rolling system. We do our best to keep Rolling as stable as Rock. Over time there are considerably more software upgrades in Rolling. The way OM devs manage things results in periods of time with relatively few or no software upgrades. Then there are times when OM devs copy what is in Cooker repos to Rolling resulting in a large amount of software upgrades at once. We do try to inform users when this happens in this forum and in OpenMandriva News. This copying of Cooker to Rolling is very carefully done.
Note: As of today 2022-05-10 that is all. This results in 430+ packages installed or re-installed. Most are re-installs.
