This is example of code posted as code:
$ cpupower frequency-info
analyzing CPU 0:
driver: acpi-cpufreq
CPUs which run at the same hardware frequency: 0
CPUs which need to have their frequency coordinated by software: 0
maximum transition latency: Cannot determine or is not supported.
hardware limits: 2.20 GHz - 3.60 GHz
available frequency steps: 3.60 GHz, 2.80 GHz, 2.20 GHz
available cpufreq governors: conservative ondemand userspace powersave performance schedutil
current policy: frequency should be within 2.20 GHz and 3.60 GHz.
The governor "ondemand" may decide which speed to use
within this range.
current CPU frequency: Unable to call hardware
current CPU frequency: 2.24 GHz (asserted by call to kernel)
boost state support:
Supported: yes
Active: no
