How To Do safer downloads from command line
Tags: #<Tag:0x00007f250d183da8> #<Tag:0x00007f250d183ce0> #<Tag:0x00007f250d183bf0>
  • OpenMandriva Lx version:
    ALL
    ALL
    Downloads get interrupted sometimes. Especially frustrating for larger downloads like ISO files.
Here’s Link: Resuming Download In Wget, cURL & aria2c - Subin's Blog
:hear_no_evil: :see_no_evil: :speak_no_evil:
Synopsis and this is quoted from that link.
Normally you would not download as root.
$ curl -L -C - -o "myfile.zip" "http://example.com/file.zip
Here is what the options mean :
## Option ## What It Does
-L Some URLs redirect to some other sites. This option tells cURL to obtain the file from that redirected location.
-C – This option is for telling cURL to resume download and the dash ("-") that follows it is to automatically detect the size of the file to continue downloading.
-o “myfile.zip” This parameter says the output location of the file being downloaded.
The last quoted value is the URL of the file. This command can be used to download for the first time as well as resuming it later.
:monkey:
$ aria2c -c -m 0 -o "myfile.zip" "http://example.com/file.zip"
Here is the explanation of each options used in the above command :
-c Tells aria2c to resume downloads
-m 0 This option will make aria2c retry downloads for unlimited times. Some servers tend to break connection after some time. But, this option makes aria2c to auto retry when such things happen.
Like before, the last quoted value is the URL of the file.
:monkey_face:
$ wget -d -c --tries=0 --read-timeout=30 -O "myfile.zip" "http://example.com/file.zip"
And here is the explanation of the options used :
-d Tells wGet to Download the File
-c Tells wGet to resume download
–tries=0 Tells wGet to retry connections unlimitedly when it is interrupted.
–read-timeout=30 If no response is received in 30 seconds, exit and establish a new connection
-O “myfile.zip” Sets the output location of the downloaded file.
Have fun downloading
:monkey:
To simplify for aria2. If I cd to the directory where I want to download an ISO file this will work just fine.
$ aria2c -c -m 0 <file_to_download.iso>
I suspect these would work as well:
$ wget -d -c --tries=0 --read-timeout=30 <file_to_download.iso>
$ curl -L -C - <file_to_download.iso>
But I have not tested the wget and curl commands yet.
