How to add supertux?
(lars martin) #1
sudo dnf install supertux
OpenMandriva 4.0 - x86_64        910  B/s | 153  B     00:00
Failed to synchronize cache for repo 'openmandriva-x86_64'
OpenMandriva 4.0 - x86_64 - Updates        1.3 kB/s | 153  B     00:00
Failed to synchronize cache for repo 'updates-x86_64'
Ignoring repositories: openmandriva-x86_64, updates-x86_64
Last metadata expiration check: 0:04:25 ago on Sun 12 May 2019 04:23:31 PM CEST.
 Problem: cannot install the best candidate for the job
  - nothing provides libboost_filesystem.so.1.69.0()(64bit) needed by supertux-0.6.0-1.x86_64
  - nothing provides libboost_locale.so.1.69.0()(64bit) needed by supertux-0.6.0-1.x86_64
(try to add '--skip-broken' to skip uninstallable packages or '--nobest' to use not only best candidate packages)
#2
This means the package supertux is actually broken. Please fill a bug report about it.
(lars martin) #3
Done: bug 2478
(Bero) #4
And fixed…
(lars martin) #5
did we use different repo? or i can not see it a difference?
#6
sudo dnf clean all && dnf install supertux
You need refresh repo meta. Above command should help.
(lars martin) #7
nice, its works, but you did not have sudo with installer, its that needed?
(Ben Bullard) #8
For ‘dnf install’ to work you need to be root (superuser). If you are in terminal as user then you use ‘sudo’ to issue a command as root. Same for most package management commands using dnf. You can use things like search and repolist that only list packages without sudo.
Post-edit: Hope this helps explain. If not ask again.
(lars martin) #9
so its should be sudo dnf clean all && sudo dnf install supertux
or Sudo dnf clean && install supertux
(Ben Bullard) #10
Keep in mind users like me are learning dnf too. This is first OM release to use dnf. To my understanding it should be"
$ sudo dnf clean all && sudo dnf install supertux
We are all, I believe including developers, learning dnf at this point in time.
