Hi Friends,
I am having trouble playing Netflix on Firefox. Any idea what might be causing the issue. No specific error code though.
Hi Friends,
I donât have a Netflix account so donât know. There is this report:
https://forum3.openmandriva.org/t/i-cant-watch-netflix-on-vivaldi-browser/3102
In which @AngryPenguin suggests that you will need h264 codec. It looks like one needs to install âmozilla-openh264â package. Thatâs my best guess.
Hint for all users: For maximum software availability remember that with OM Lx 4 only the âMainâ repository in enabled by default. So for maximum software availability one needs to enable other repositories with âSoftware Repository Selectorâ.
Post-edit: Apologies. I had incorrectly stated that the suggested package was in unsupported repository. It is not, it is in âMainâ repo. So no repository need be enabled for that particular package. Might as well leave the rest of my post as is.
@Blake_Lehner what version of firefox are you using , I use it to watch netflixs , itâs version 69.0.1
you might just need updated version of firefox.
or just enable DRM media in Firefox --> Preferences --> Digital Right Management (or sometings like that).
After this FF should download Widevine plugin and then Netflix should work.
