I need pkg-config in order to compile aqualung Compiling
for that it needs glib-2.0 but cant find it. Is it a bug? Who can help? Thanks.
$ rpm -qf /usr/bin/pkg-config
pkgconfig-0.29.1-1-omv2015.0.x86_64
file /usr/bin/pkg-config: No such file or directory
rpm -qf shows the pkg who provides the file(if installed) or you can use urpmf pkg-config.
install pkgconfig
configure: error: Package requirements (libxml-2.0) were not met:
No package ‘libxml-2.0’ found
pkg-config problem has been solved?
I’ve not heard “thanks”
seems so, yes
i’m used to say thanks at the end of the way see last topics or you missed the first post
