[root@pujitha-pc ~]# urpmi --update --auto-select
(medium “non-free updates”)
flash-player-plugin 27.0.0.187 1 omv 2015.0 x86_64
flash-player-plugin-kde 27.0.0.187 1 omv 2015.0 x86_64
0B of additional disk space will be used.
17KB of packages will be retrieved.
Proceed with the installation of the 2 packages? (Y/n) y
http://downloads.openmandriva.org/mirrors/openmandriva.3.0.x86_64.list: media/non-free/updates/flash-player-plugin-27.0.0.187-1-omv2015.0.x86_64.rpm
http://downloads.openmandriva.org/mirrors/openmandriva.3.0.x86_64.list: media/non-free/updates/flash-player-plugin-kde-27.0.0.187-1-omv2015.0.x86_64.rpm
installing flash-player-plugin-27.0.0.187-1-omv2015.0.x86_64.rpm flash-player-plugin-kde-27.0.0.187-1-omv2015.0.x86_64.rpm from /var/cache/urpmi/rpms
Preparing… ######################################################################
Note that by downloading the Adobe Flash Player you indicate your acceptance of
the EULA, available at http://www.adobe.com/products/eulas/players/flash/
Downloading from http://fpdownload.macromedia.com/get/flashplayer/pdc/27.0.0.187/flash-player-npapi-27.0.0.187-release.x86_64.rpm:
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 8790k 100 8790k 0 0 799k 0 0:00:11 0:00:11 --:–:-- 847k
Downloading from http://fpdownload.macromedia.com/get/flashplayer/current/licensing/linux/flash-player-npapi-27.0.0.187-release.x86_64.rpm:
100 286 100 286 0 0 286 0 0:00:01 --:–:-- 0:00:01 650
Downloading from http://linuxdownload.adobe.com/linux/x86_64/flash-player-npapi-27.0.0.187-release.x86_64.rpm:
100 8790k 100 8790k 0 0 732k 0 0:00:12 0:00:12 --:–:-- 767k
Error: Unable to download Flash Player. This is likely due to this package
being too old. Please file a bug report at https://issues.openmandriva.org
so that the package gets updated. Thank you.
In the meantime, you can download Flash Player manually from
http://get.adobe.com/flashplayer/
ERROR: ‘script’ failed for
error: %pre(flash-player-plugin-27.0.0.187-1.x86_64) scriptlet failed, exit status 1
error: install: %pre scriptlet failed (2), skipping flash-player-plugin-27.0.0.187-1.x86_64
error: %pre(flash-player-plugin-kde-27.0.0.187-1.x86_64) scriptlet failed, exit status 1
error: install: %pre scriptlet failed (2), skipping flash-player-plugin-kde-27.0.0.187-1.x86_64
