# urpmi flash-player-plugin
Marking flash-player-plugin as manually installed, it won't be auto-orphaned
writing /var/lib/rpm/installed-through-deps.list
http://abf-downloads.openmandriva.org/3.0/repository/x86_64/media/non-free/updates/flash-player-plugin-25.0.0.171-1-omv2015.0.x86_64.rpm
installing flash-player-plugin-25.0.0.171-1-omv2015.0.x86_64.rpm from /var/cache/urpmi/rpms
Preparing... #######################################################################################
Note that by downloading the Adobe Flash Player you indicate your acceptance of
the EULA, available at http://www.adobe.com/products/eulas/players/flash/
Downloading from http://fpdownload.macromedia.com/get/flashplayer/pdc/25.0.0.171/flash-player-npapi-25.0.0.171-release.x86_64.rpm:
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 277 100 277 0 0 1102 0 --:--:-- --:--:-- --:--:-- 1178
Downloading from http://fpdownload.macromedia.com/get/flashplayer/current/licensing/linux/flash-player-npapi-25.0.0.171-release.x86_64.rpm:
100 286 100 286 0 0 1145 0 --:--:-- --:--:-- --:--:-- 1217
Downloading from http://linuxdownload.adobe.com/linux/x86_64/flash-player-npapi-25.0.0.171-release.x86_64.rpm:
100 259 100 259 0 0 3629 0 --:--:-- --:--:-- --:--:-- 5755
Error: Unable to download Flash Player. This is likely due to this package
being too old. Please file a bug report at https://issues.openmandriva.org
so that the package gets updated. Thank you.
In the meantime, you can download Flash Player manually from
http://get.adobe.com/flashplayer/
ERROR: 'script' failed for
error: %pre(flash-player-plugin-25.0.0.171-1.x86_64) scriptlet failed, exit status 1
error: install: %pre scriptlet failed (2), skipping flash-player-plugin-25.0.0.171-1.x86_64
New release is
the script should be updated accordingly, IMO.
Yeah, thanks Raphael. I think the reason the script stopped working is only because our version is to old. Would be awesome if someone has time to do a package request bug report on this.
I’m busy with family matters at the moment.
fixed
Thank you fedya.
fedya, my thank you was sincere but unfortunately the script still fails:
(medium "non-free updates")
flash-player-plugin 26.0.0.126 1 omv 2015.0 x86_64
error: %pre(flash-player-plugin-26.0.0.126-1.x86_64) scriptlet failed, exit status 1
error: install: %pre scriptlet failed (2), skipping flash-player-plugin-26.0.0.126-1.x86_64
error: %pre(flash-player-plugin-kde-26.0.0.126-1.x86_64) scriptlet failed, exit status 1
error: install: %pre scriptlet failed (2), skipping flash-player-plugin-kde-26.0.0.126-1.x86_64
removing installed rpms (flash-player-plugin-kde-26.0.0.126-1-omv2015.0.x86_64.rpm flash-player-plugin-26.0.0.126-1-omv2015.0.x86_64.rpm) from /var/cache/urpmi/rpms
i rebuilt it, just try to install again.
installing flash-player-plugin-26.0.0.126-2-omv2015.0.x86_64.rpm from /var/cache/urpmi/rpms
Downloading from http://fpdownload.macromedia.com/get/flashplayer/pdc/26.0.0.126/flash-player-npapi-26.0.0.126-release.x86_64.rpm:
100 277 100 277 0 0 1369 0 --:--:-- --:--:-- --:--:-- 1720
Downloading from http://fpdownload.macromedia.com/get/flashplayer/current/licensing/linux/flash-player-npapi-26.0.0.126-release.x86_64.rpm:
100 286 100 286 0 0 1582 0 --:--:-- --:--:-- --:--:-- 2057
Downloading from http://linuxdownload.adobe.com/linux/x86_64/flash-player-npapi-26.0.0.126-release.x86_64.rpm:
100 8772k 100 8772k 0 0 635k 0 0:00:13 0:00:13 --:--:-- 778k
1/1: flash-player-plugin ################################################################################
Adobe Flash Player installation successful.
fedya, yes it works now. Awesome. Thanks again.
