I still have one OMV LX303 installation and after updating firefox to 67.0.1 I simply lost all my personal data.
Firefox said it would not use my personal data in that computer.
Made many attempts to recover but no luck. Firefox is out!
Sad!
Sad!
run in terminal
firefox -p
then in new window select your previous profile (default) and restart browser.
Should help.
Obviously I failed but the whole point of this post was to alert forum users to this change and further to explain that Mozilla puts up an initial information page telling you what to do to recover your data and settings.
Also to let users know this has nothing to do with OpenMandriva or what version of OM you are using, this is strictly upstream decision making by Mozilla.
I got caught with this update that seems to me it tends to open a firefox account to save the data (once again or and to do what?). I got the bookmarks in .mozilla / firefox / bookmark backup or something similar but I lost all my passwords âŚ
$ firefox -p
(firefox:5076): Gtk-WARNING **: Theme file for default has no name
Although my original profile
(firefox:5076): Gtk-WARNING **: Theme file for default has no directories
JavaScript error: resource://gre/modules/XULStore.jsm, line 60: Error: Canât find profile directory.
JavaScript error: resource://gre/modules/AsyncShutdown.jsm, line 674: Error: Phase âxpcom-will-shutdownâ is finished, it is too late to register completion condition âUserInteractionTimer 1 for document 7f891ee1c000â
My old profile is in .mozilla/firefox, Iâve double checked.
Iâd bet you new profile is in the same place. .mozilla can hold many different profiles.
Your output of âfirefox -pâ is weird. The GTK warnings are meaningless. The rest of it looks like somethings are broken so you needed a new profile anyway. For any missing data look in .mozilla/firefox for your old profile if it isnât there this issue is over.
Normally installing or updating firefox does not remove your old profile it just creates a new one and gives all the error dialogs to scare the beejezus out of unsuspecting users. And normally all you have to do is run âfirefox -pâ and use the old profile. At this time.
In fact, this morning I noticed,
firefox -p
worked fine for another user.
Besides .mozilla/firefox
, Firefox also has something in the directory
.cache/mozilla/firefox/
I probably removed the latter in attempts to make new firefox look at my old profile.
I mean, the only way to recover my old profile is if I could move the content of .mozilla/firefox to .cache/mozilla/firefox, somehowâŚ
You need to go to MozillaZine Firefox forum and ask there. As I understand .cache is something limited to temporary things like cookies and other things, it is one of the first things they recommend to erase if you have problems in Firefox so I doubt there would be any significant data there. But do you self a favor and ask people that know more at MozillaZine Firefox forum.
I dont know how to resolve your issue but lets try in other way.
Open firefox and go to about:profiles
then you can see all available profiles here and click on make a default on your previous profile.
If you use Firefox Sync then everything it saves will be there for any new profile. I do not believe Firefox Sync will save passwords, but I could be wrong. Hereâs what it does save or âsyncâ:
Most developers and system administrators are leery of saving passwords for obvious security reasons. And a big part of what Mozilla is trying to do involves security. Also see @AngryPenguinâs tip about using âabout:profilesâ it is good one.
about:profiles was one of the first things Iâd tried. But, any way, Iâll try again before contacting MozillaZineâŚ
Thanks for the tip
Well I hope you get it worked out. And I am by no means an expert on Firefox. You or @AngryPenguin both seem to be more knowledgeable on FF than I.
