dnfdragora-updater/Python3.7m closed unexpectedly
After updates I got a dnfdragora-updater icon at panel. I clicked on it in the option “open dnfdragora-dialog” and closed the dnfdragora window that pop up. Then, the dnfdragora-updater icon changed and I got that message:
python3.7m closed unexpectedly
Sorry if messages were not properly translated …
Yes, I saw that error after selecting “Check updates”
I hope it is OK that I changed the title to hopefully be a bit more descriptive. I have a feeling that this application is not working properly and if not we certainly need to get it fixed.
So what I am doing is I restarted this application from command line (Konsole) as user like:
$ dnfdragora-updater
and let it sit for half a day or more and see what happens. Then I’ll have Konsole output to post with I hope some indication of where to look next.
Also there is this:
$ coredumpctl
Thu 2019-01-17 19:51:49 CST    1437  1001  1006  11 present   /usr/bin/python3.7m
And I believe this is the same event from journalctl:
Jan 17 19:51:32 ben79-pc dbus-daemon[806]: [system] Activating via systemd: service name='org.baseurl.DnfSystem' unit='dnfdaemon.service' requested by ':1.40' (uid=1001 pi>
Jan 17 19:51:32 ben79-pc systemd[1]: Starting Package management dnf daemon...
Jan 17 19:51:32 ben79-pc dbus-daemon[806]: [system] Successfully activated service 'org.baseurl.DnfSystem'
Jan 17 19:51:32 ben79-pc systemd[1]: Started Package management dnf daemon.
Jan 17 19:51:49 ben79-pc systemd[1]: Created slice system-systemd\x2dcoredump.slice.
Jan 17 19:51:49 ben79-pc systemd[1]: Started Process Core Dump (PID 6823/UID 0).
Jan 17 19:51:49 ben79-pc systemd-coredump[6824]: Failed to generate stack trace: Unwinding not supported for this architecture
Jan 17 19:51:49 ben79-pc systemd-coredump[6824]: Process 1437 (python3) of user 1001 dumped core.
Jan 17 19:51:49 ben79-pc systemd[1]: systemd-coredump@0-6823-0.service: Succeeded.
Jan 17 19:51:49 ben79-pc systemd[1]: systemd-coredump@0-6823-0.service: Consumed 208ms CPU time.
I’ve enabled systray integration, as discover was removed from ISO (weird decision imho).
https://github.com/OpenMandrivaAssociation/dnfdragora/commit/e2e8d679f3fb2e97ebb371f84ece430c95abd980
So today there are updates and when I select dnfdragora-updater to update I get his result:
Screenshot_20190118_085243
But it seems like the updates were updated.
Konsole output of this event:
python3.7m.txt (430.6 KB)
