I wanted to do some work on my BTFRS Home partition. Since I had to do that, I decided to distro-hop. I wanted to try some other non-woke distros so that leaves out many including Fedora, Ubuntu (yuck), KDE neon, openSUSE, Linux Mint, and Debian all of which I have tried in the past. I wanted to try both LCOS and Devuan again. Here is how it went:
LCOS (Lunduke Computer Operating System)
- It’s interesting, but I have never been a fan of XFCE.
- I tried installing SonicDE, but it is not ready for prime time unless you want to try switching repositories over to TESTING or UNSTABLE which I assume would affect everything.
- I installed KDE Plasma. There were a lot of bugs with it. My time is precious so I gave up.
- It might be worth a look in the future if it has an official SonicDE version.
Devuan Excalibur
- I installed the KDE Plasma version of Debian Trixie then converted it to Devuan Excalibur using the directions on their website.
- This went fine, but you need to be hooked up to the Internet with an ethernet cable as you cannot finish the setup properly using wireless.
- SysVinit is not as good as SystemD especially for KDE Plasma.
- I began noticing software was out-of-date especially KDE Plasma itself. Typical Debian.
- I began adding repositories to get the latest versions of Firefox, Thunderbird, OnlyOffice, etc. After adding a bunch, I began to realize using Flatpaks instead is WAY EASIER.
OpenMandriva Rome
- HOME SWEET HOME!
- I installed OM, rebooted, and removed apps I never use to make my own “Slim” version. Thing like kwrite, kcalc, kmail, kaddressbook, etc.
- Installed Steam via
sudo in steam. - I decided awhile back to use Flatpaks as often as possible to have the latest apps. Here is a great way to install up-to-date apps IMO. Heck, most are now going to Flatpak as the preferred way to get apps.
- I installed and configured firewalld and ClamUI.
- Sprayed virtual “Round-Up” on the flowers.
Now I can get back to work instead of farting around with distro-hopping… now with a properly configured /home partition using BTRFS subvolumes for snapshots.
