Testing iso build 14342.
On the left: systemsettings of root, on the right: sistemsettings of user.
I think this is normal, because you have different users, with different settings.
In build 13342 when I opened rpmdrake window was to dark to see what I was trying to do. In other words root windows are dark, to dark to do work.
@Sirius It’s matter of consistency. And of why not to have the same settings everywhere - at least at the beginning, after the users can make their choice if they wish.
Look:
Quiz: Find the differences.
@ben79 Yes.
I bet it’s because of some_settings somewhere (where?? if we see so much different settings everywhere, hard to discover I guess).
rugyada: I ran ‘kdesu systemsettings5’ in Konsole as root and changed some things so I could see what I was doing. I wouldn’t say this is a show stopper but on the other hand should be easy to fix. Another bug report?
@ben79 Not a showstopper, sure, but a nonsense and sign of carelessness maybe =)
imho.
Postedit:
Feel free to open a bugreport. You’ll be able to better explain than me
I found out that
open a root konsole
type systemsettings5
set “Select GTK2 Theme” as -> Breeze in Application Style
Apply
did the trick for black Control Center appearance. It fixes also the menu height and give an overall better look.
